Fuse Question
Would it be a good idea to fuse the wires that are connected directly to the battery + or are they fused elsewhere? Thanks in Advance.
Old 11-21-2010, 06:19 PM
Band.
If you want to fuse them you need to find out what they are so you can determine a fuse value anyway; so finding out what they are is a good first step.
Old 11-21-2010, 06:27 PM
Fleabit peanut monkey
Bob Kontak's Avatar
I would think all would be fused elsewhere but do what Gogar suggests to make certain they are.
Old 11-21-2010, 06:31 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Fuses
Without knowing your model/year it is very questionable as what is and what is not fused.
As an example, I fused several items which I thought, were lacking on our '86.
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 11-21-2010, 08:07 PM
The car is a 1975 911. The wires are a #10 & #12 Ga. with a ring terminal bonding them together. The other is a #12 with a ring terminal. Both sets enter the factory wiring harness.I have already removed all the patched wiring, all the wiring diagrams I can find are unreadable.
Old 11-22-2010, 06:00 PM
Electrical diagrams.........
Jim,
The secondary lines are usually all going to a fuse box. But the primary lines like ignition switch and starter are direct lines from the battery. What particular circuit are you talking about? Let us know what are you planning to do and we'll look at the wiring diagram for suggestion/s. Keep us posted.
Tony
Old 11-22-2010, 06:50 PM
Bob Kontak's Avatar
Did not know the ignition switch was not fused. Every day is a learning adventure.
Old 11-22-2010, 06:53 PM
Some more......
Bob,
There are several electrical components (SC's) that get direct power from the battery (via ignition switch) without going through a fuse. Some of these on top of my head are:
CSV (cold start valve)
FP relay @ 87
Starter solenoid @ 50 (yellow wire)
CDI @ 15
Parking lights
Dashboard illumination lights (fuel gauge, speedo-meter,tachometer, etc.)
Horn relay
And probably many more that I could not remember now.
Tony
Old 11-22-2010, 07:34 PM
Bob Kontak's Avatar
Is there a fuse downstream of the component? No need to answer, Tony. I will look at the diagrams in the morning. Thanks much.
Old 11-22-2010, 07:45 PM
If a conductor, weather it be a 12v or 600v travels inside anything it needs to be fused. This is a no brainer.
Old 11-23-2010, 06:24 PM
