Transmission case: is this crack going to be a problem?
While cleaning, I noticed this hairline crack. How concerned should I be?
1983 SC
Blog
Old 11-27-2010, 05:52 PM
there are plenty of threads about "cracks" on transmissions that are only casting marks, but yours sure looks like a real crack. it will be a problem now or later if it is.
206 637 4071
Old 11-27-2010, 06:09 PM
Max Sluiter
Flieger's Avatar
Up on the very top where it is on the fin, it looks like it is a raised casting mark to me.
Old 11-27-2010, 06:11 PM
Hodgey's Avatar
can you inset anything into the 'crack'? If not then as Flieger suggests, it may be a raised casting mark.......
Neil
1987 Carrera, Grand Prix White, 2009 Carrera C4S, Meteor Grey Metallic
(X) [B] 2011 BMW X5[B]
'Success is not final, failure is not fatal. It is the courage to continue that counts'
Old 11-27-2010, 06:15 PM
If thats a crack, you do have a serious problem.
Zyglow testing is the way to confirm whether its casting flash or a crack.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 11-27-2010, 06:32 PM
Certified Pre-Owned
BGCarrera32's Avatar
Based on how that runs from the very top of the case all the way down to the bearing I would be extremely suspect of that...
'84 Carrera Coupe
Old 11-27-2010, 07:25 PM
slodave's Avatar
I say casting mark...
Looks like it's in the same position as this...
(Taken from this thread and reversed...)
Crack, a big social problem....worse in a 915
Actually, they look identical.
Old 11-27-2010, 07:33 PM
Max Sluiter
Flieger's Avatar
Nice one, Dave!
Old 11-27-2010, 07:37 PM
Certified Pre-Owned
Wow. I stand corrected.
'84 Carrera Coupe
Old 11-27-2010, 08:10 PM
Manassas, VA
lucittm's Avatar
Probably caused by a crack in the mold. It might take a few castings before they catch it at the foundry and then make a new mold or repair the old one. Ironically with a bit more metal on the outside of the case it is stronger than a case without the additional flashing. Because it was molded in and not machined, it would not be a stress riser.
Mark
1991 964 Polar Silver Metallic Turbo Coupe
Old 11-27-2010, 09:32 PM
Dave, that's almost freaky. I know nothing about casting and assumed the mark was either a sign of insignificant fatigue or of severe stress of what nature I can't imagine. Anyway, this is encouraging.
Old 11-27-2010, 10:03 PM
slodave's Avatar
A link to a thread from Zef, with the same problem.
Is it a crack ?
I'm sure there are a lot more out there that look like yours and the others, they just have miles of crap covering them.
Don't worry about it and keep driving.
Old 11-27-2010, 10:19 PM
D911SC's Avatar
This picture of mine may make us both feel better!! I was sure it was a crack but there are no leaks or other symptoms.
Mine is 915 from ROW 83 SC.
Note pic is upside down to match the other ones in this thread.
My first love - 1993 964 C2 Manual Coupe
My second love - 2021 Macan GTS
Old 11-27-2010, 11:22 PM
turbojem's Avatar
Porsche Crest
i cleaned my 915 about a week ago went back ,& did a little more today and saw the IDENTICAL crack (or what i thought was a crack ) , i wondered why there wasnt oil all over the garage . Very happy to have found this thread about the casting mark . - Id post a pic but looks exactly like youz allz same location too . '84 carrera Kinda relieved - i think ?
'84 Carrera (Red)
Old 08-31-2013, 11:34 AM
Taking it apart is easy
Jerome74911S's Avatar
Evidently that crack remained in Porsche's mold for a serious amount of time. My car is older, but I'm going to crawl under there and have a look anyway.
Nice to know.
Jerome
PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com
Old 08-31-2013, 01:19 PM
Walt Fricke's Avatar
It should be pretty easy to determine if this is a casting mark. Get in there with a power tool with a suitable abrasive - the round small bodywork sandpaper pieces with a fine grit on a die grinder, for instance. If this is raised, rather than indented, you'd grind it off, leaving a smooth surface.
And you could do this in just a small part of it.
If, as I suspect, this is actually an indentation, you could still try this. You could even use another kind of tool to see how deep it is. Maybe do it where it appears on the tip of a rib. If it is a crack, you haven't made anything worse. If it isn't, but is a shallow casting groove, you still haven't made anything worse.
In fact, maybe, if a groove, you could just use a scratch awl or machinist's scribe to scrape it a bit to determine where it stops.
In my experience, transmission cases are most often cracked from two causes. One involves broken parts getting in the teeth between pairs of gears, forcing them apart. The other involves accidents with the car (those I have seen have been on the race track), where a rear tire slams into a wall or another car. The force gets translated through the axle right into the differential housing. Or the rear frame rails get bent enough to break the bell housing portion.
If you know the history of the box, you might be able to rule in or out the chances of something like this happening.
I don't know enough about aluminum to know if a long crack like this could develop but not be full depth - not all the way through. Seems unlikely in a casting like this - I'm not sure it would develop like the typical bolt fatigue fracture, where once it snaps you can see the progressive nature of the failure, starting from a stress riser point and getting larger.
On a 911 gear box, I think the normal side thrusts from the ring and pinion are to the left (driver's side). Which is why you can get aftermarket reinforced cover plates if you have a monster motor. I'd not expect that on this right side.
If your photo is upside down (and it looks a lot like slodave's), then this is in the lower side of the transmission, where there is a lot more oil. Which means the lack of oil suggests it isn't a crack, or if it is, it isn't all the way through. Transmission oil, while rather thick, is quite good at making its way out of things if it has the opportunity.
Old 08-31-2013, 03:29 PM
Magnaflux
Wouldn't it be nice if there was some way of testing these things without destroying the material???
Old 08-31-2013, 03:34 PM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
While Magnaflux won't work, dye penetrant most likely will!
Nicely played....
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 08-31-2013, 04:45 PM
1985 Carrera
Old thread but thought I'd join in. My 1985s transmission has the exact same marking.
Old 01-23-2023, 01:45 AM
So maybe it was a casting artifact? If so, I'd hesitate to call it a flaw.
Old 01-23-2023, 02:01 PM
