Sugar Scoops Rule :)
dave 911's Avatar
Rear bleed nipples different size from front?
Do all 911's have different size bleed nipples on the rear and the front? I did a search and couldn't find anything....
I've got my system all put back together after replacing the brake lines and rebuilding the front calipers, and notice (to my dismay, as I don't have a small enough wrench) that the rears are smaller than the fronts. 9mm on front, looks like 7mm on the rears?
Always looking for a good excuse to buy more tools .
Is this the stock set-up? If so, why?
tia
Dave
_______________________________________________
'76 911S Targa
'62 VW Type 1 Sunroof
'73 914 2.0 (1st Porsche, gone long ago but not forgotton)
Old 11-28-2010, 03:10 PM
Senior Advisor
James Brown's Avatar
Sometimes replacement bleeders are different size but the hole is the same, Get some speed bleeders and the will be all the same.
08 Cayenne Turbo
Old 11-28-2010, 03:20 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Yes - I believe the rears are 7mm. Just did mine two weeks ago.
Old 11-28-2010, 03:22 PM
Daytona's Avatar
On mine they are all 9mm and the line size is 11mm. 911 get it!
Larry
88 911 Carrera Coupe Metallic Silver
Old 11-28-2010, 03:44 PM
