911R taillight questions
1) My housings have some small holes/bubbles in the top coat (pictured below). What's the best way to patch or fill these before I finish priming and painting? Caulk?
2) Does anyone know where to get a five-wire connector like the one AR Concepts uses to wire the lights? (pictured below)
'73 CIS T with a 3.2 on a stand in the corner
Old 11-28-2010, 08:32 AM
Information Junky
island911's Avatar
r-gruppe rules mandate that those holes must be filled with special super small carbon fibers called Buckey-tubes. ...and finished to a 32 or better surface.
...or use toothpaste.
Seriously, any paint filler will work.
Old 11-28-2010, 09:12 AM
I suppose I deserve that. I'm (obviously) not a body work guy--I didn't know there was such a thing as "paint filler"
Old 11-28-2010, 09:26 AM
haycait911's Avatar
two part putty. commonly called icing. do not use a single component filler, you will be sad later.
Old 11-28-2010, 09:33 AM
AutoBahned
RWebb's Avatar
don't drive yourself insane - leave the real tiny holes; you will use a high build primer to fill those
keep your microscope locked away in its cabinet and stay calm
Old 11-28-2010, 11:53 AM
1986 Targa 1972 RS clone
magnuskgc's Avatar
use red finishing putty.. apply with a single edge razor (as your spreader) it will finish all of the small pin holes.
Old 11-28-2010, 02:50 PM
