spark plug tool
can someone point me to where I can buy the spark plug tool? I've searched forever and can't find where to buy one (ebay has none, someone suggested looking there)
thanks in advance 1982 sc 3.0l |
Northern Motorhead
You have to keep a keen eye on the classifieds forum ... tool kits as well as seperate items like fan pulley wrenches and spark plug tools come up regularly !
Cheers ! Phil
Cheers Phil 89 Coupe,Black,95 3.6 engine and the list goes on ... 1983 944 SP2 race car PCA #96 |
Youll need to pay shipping... but here you go...
Spark Plug Wrench Porsche 911 / 914 / 964, Porsche | Design 911
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. |
I have one if you are on the states.
E-mail me. |
Forgive my ignorance, what is special about this tool? Flexes for tight spots?
1987 Triple Black Cabriolet - Wide Body 2011 Black Cadillac SRX 2007 Black Honda Element SC 5spd (for sale!) 2015 Yukon XL Denali 1966 VW Karmann Ghia |
Band.
I don't have one, so I use a 3/8 drive swivel spark plug socket, and tape it to a 3" extension, and it works.
1983 SC Coupe 1963 BMW R60/2 1972 Triumph Tiger 1995 Triumph Daytona SuperIII |
I actually want one to use. I tried a homebrew solution but quickly learned having the right tool is always so much easier.
Bob, sent you an email. thanks |
This adjustable HAZET worked well for me...loved by VW & 914 guys as well...
![]() 3/8" drive stubby ratchet plugs right in...the moulded wheel is for finger starting so you don't cross thread. the center adjustment works best for 911...but can be made shorter or longer, your choice.
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) Last edited by pwd72s; 12-08-2010 at 09:58 AM.. |
My solution was a standard Craftsman 13/16 spark plug socket that has a joint connected to it...$10.00...I tied a piece of string through the joint and just pull it out every time. all you need is this and an extension.
John W
The original tool flexes just right and really makes the job easier - I like it but I'm sure others have good solutions just the same.
----------------------------------- John 89 3.2 Targa 123k miles |
NOS driver
the Hazet tool is just perfect. I also use it at mid position, but when I pull the plugs off I make it shorter so the plugs can come out very easily!
To remove and install the sparks from my SC I built this costless tool with an old spark plug wrench and a 14 mm. steel sleeve
![]() ![]() ![]() When the spark runs freely, I extract it with a rubber tool bought at a motorcycle equipment shop . ![]() The work is very fast and I do not run the risk of dropping the candle in the inside ![]()
Paolo from Alps 1980 911 Targa SC 3.0 - Silver metallic 1980 Ducati Pantah 500 - Red 1989 Yamaha 500 "Tracker"
Paolo...ingenious!
Necessity was the mother of invention?
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
Or you could just stop being cheap and buy the proper tool. Its one you will use over and over again...
Some of my favorite tools.......
While I usually enjoy making some special tools for my needs, there are a couple of tools worth the money I spent. These are the valve adjustment and spark plug tools in my tool box.
![]() A 13/16" spark plug tool with flex joint and a 3" extension with locking feature do a good job for 911 engines. There is more satisfaction for some people when you make or build your own tools than just buying them over the counter. Tony |
boyt911sc - please provide the mfr part no for the valve adjustment tool
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
Tool information.........
Just keep an eye out on this forum and ebay. It's funny when you are looking for something it's usually hard to find. So start thinking about something else you want to buy and you'll probably find three guys selling a spark plug tool.
BTW...the first time I changed spark plugs I didn't have it and taped extensions together. Not terrible, but after you have the tool, you realize how much easier it is.
Matt. 83 911SC 85.5 944 NA - Sold |
For professional results...this socket (SnapOn w/internal magnet) has, with my hands and a combination of (1) 3" extension, and (1) 1" extension, replaced thousands of 911 spark plugs. The exterior of the socket must be machined slightly to help with cylinder #1.
Keep the Shiny Side UP! Pete Z. |
