1986 Targa 1972 RS clone
Power seat help
So I have a power seat in my Targa. I have "bench tested" the seat and when I connect power to the connector under the seat all of the motors work.
The switch appears to be bad.. has anybody had experience changing out these? I am trying to decide between fixing the seat or changing to racing seats? It is a road car so I don't "need" racing seats.. any help would be appreciated. |
"O Gruppe 13"
to what switch you are refering? i do have two seats dismanteled to pieces, might have what you need.
G-Man 89 964 C4 86 930 |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
It worked for me. Lots of posts on cleaning seat switches.
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Flat Six
Magnus, changing out the power seat switch(es) is not hard; you have most of the difficult work (seat removal and system testing) out of the way already. Couple of suggestions based on my experience:
1) replace the switch(es) with new; I've tried several times and cleaning/repairing old switches has never worked out for me (YMMV) 2) toughest part of R&R is threading the new switch's wiring through the seat frame in the side bolster; patience here is a must 3) if the surrounding trim piece is cracked (many are), now is a great time to replace it. They often crack because they're not properly seated flush against the bolster and switch faces; this is easier w/seat out IMHO 4) of course, clean & lube seat tracks and clean & condition hard to reach leather while you have the seat out 5) fully test function when powered by harness before bolting in seat (yes, I learned the hard way) 6) fully raise seat bottom F&R before bolting in -- much better clearance to access seat bolts 7) critically inspect hex sockets of seat bolts and replace any that look remotely like they're getting rounded and use a little anti-seize when replacing. Hope this helps, and good luck Dale
Dale 1985 Carrera 3.2 -- SOLD 2026 Jaguar F-Pace / 2025 Ford Bronco Sport |
thanks guys.. I am referring to the six way power switch on the side.. I have tried to clean the switch the best I can..
Dale that helps ALLOT... I did replace the seat bolts and actually the mounting blocks underneath too (fabricated new ones).. You don't happen to have pics or anytihing that would assist in routing the wires in to the seat? |
Flat Six
Good luck Dale
Thanks... when I get moving again.. it will be the next probject I tackle.
While you are spraying the contact cleaner, rock the switches left to right and up and down. Do not use WD40. This will get the cleaner into the contact. I would not dis-assemble the switch. Good luck, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." Last edited by 86 911 Targa; 12-08-2010 at 04:10 PM.. |
muck-raker
There's this thread....
"how-to" fix power seat switches...... Also, there's another thread where a Pelican has a step-by-step procedure with pix on replacing the switches with new. A quick search should yield results.
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
seats
what do you use to clean?? Is there a specific cleaner? and where does one purchase it? I may try that before I spend the money on new switches... maybe it will buy me some time
"O Gruppe 13"
.....have this ( Driver Side)
![]() ....or you could take from here ( Pass Side)
Flat Six
CRC makes a nifty aerosol cleaner for electrical contacts (red can). Available at your FLAPS.
I assume FLAPS is a local auto parts chain in CA? lol.. don't have them out here.. I will try the local stores.
I think he means Favorite Local Auto Parts Store.
"Friendly" local auto parts store. Like it better.
In my audi had same problem. I tried several times with electric contact cleaner is around 7 bucks and did the job. |
Flat Six
Sorry, my bad -- got a little lazy at the keyboard
Weekend Mechanic
Nu-Trol contact cleaner is what I have used to bring my seat switches back to life. Here's a link;
Control Cleaner
86 911 Carrera Targa
OOOOH!..... I get it.. lol... I am lost with the computer lingo without my daughter to help (and he is only 9... God help me)
still trying to located the cleaner.. I was told today that maybe Staples or Office max...
Flat Six
NAPA Online CRC also makes a cleaner specifically for QD (quick-detach) electrical plugs -- harder to find and Lectra-Motive works just as well for this application, I think: Amazon.com: CRC 05101 QD Electronic Cleaner - 4.5 Wt Oz.: Automotive HTH Dale
