footwell blower problem
Hi,
I have an 84 carerra with the manual 3 speed switch for the footwell blowers and they were working fine the other day.Today i turn them on and they run for a split second and then turn off.The engine compartment blower works fine and all fuses are fine.You can keep pulling up the levers and pushing them back down and hear them run for a split second but they shut off.Any ideas what might be causing this?
Jay
Old 12-06-2010, 08:47 AM
MattKellett's Avatar
I expect they've seized!
This pretty much happens to every car at one time or another.
Have a look in the archives and you'll find quite a few threads on how to take them apart and grease them up again.
Good luck
Matt Kellett
87 Carrera Coupe - Marine Blue
60 MGA - Chariot Red
66 Jaguar MKII - Sherwood Green
09 VW GTI - Candy White
Old 12-06-2010, 09:14 AM
I think you might need to clean the low voltage contacts in the heater relay, which is in the engine compartment. Buying a new one is really expensive. If you rev the engine, do they stay on?
Old 12-06-2010, 09:26 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Do a search under Footwell Blower Motor Fix.
Member ibeaudoin posted a great step by step fix
which worked well for me.
Unfortunately, I don't know how to paste a link
onto a thread.
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 12-06-2010, 09:32 AM
Wayah Road Warrior
Shadetree930's Avatar
onto a thread.
Good luck,
Gerry
Footwell blowers squeaky, how to fix.
02 996tt White
87 930 GP White (Sold)
87 911 Targa Guards Red(Sold)
Old 12-06-2010, 10:13 AM
aj88cab's Avatar
Do you have a non-OEM replacement motor on the engine blower?
I had this exact problem when I installed the replacement blower discussed in this thread...
Carrera replacement heater blower (long)
See post #65 for my theory. I replaced the Dayton motor with an OEM motor and everything worked fine.
If you have an OEM engine blower motor check and clean your ground connections. Pull the connector off the engine blower control unit (located on the electrical fuse/relay panel in the engine compartment) and clean the contacts (as Rusnak mentioned above).
If that doesn't help, see if you can borrow a (known good) engine blower control unit and install it to see if your control unit is bad. Try your control unit in the donor car too.
I don't think your problem is the footwell blowers themselves but you can check them by running power to them directly.
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires
'86 944NA, Sunroof Delete, Track Rat, Full Cage
'72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic
Old 12-06-2010, 10:41 AM
thanks for all the replies...i'll check a few things tommorow and check in with any progress or not....may as well show a pic of my pride and joy
Jay
Old 12-06-2010, 05:14 PM
i did the jumper wire mod in the heater control unit and now they work perfect....turn the switch off and they shut off all the way....push the levers off and they shut off... also all speeds work.I don't post alot but i check the forum almost daily...this is the best and most active forum i have come across in all my hobbies and interest that i'm into.
thanks for the help
Jay
Old 12-08-2010, 10:14 AM
