sach's power clutch Kit VS. sachs standard clutch kit
I am getting ready to replace the clutch on my '83 911sc. What is everyone's thoughts and experiences with the power clutch kits and regular clutch kits?
Are the power clutchs harder to shift and are they not for daily city use? Thanks in advance! James |
I used the power kit in a 1980 SC with a 3.6 . I could hardly tell any difference re pedal effort. The pressure plate is aluminum and lighter than stock. Pelican doesn,t list a power clutch as available anymore.
1980 911 SC 3.6 coupe sold 1995 993 coupe 1966 Mustang Shelby clone 1964 Corvair Spyder Turbo gone 2012 Boss 302 |
On a stock street car probably no advantage...
Here is the info/link 3000-961-101-M38 SACHS Power Clutch, 911 (1972-86) [More Info] $791.50 http://www.pelicanparts.com/cgi-bin/smart/more_info.cgi?pn=3000-961-101-M38&catalog_description=SACHS%20Power%20Clutch%2C%20%3 9%31%31%20%28%31%39%37%32%2D%38%36%29
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. |
I put the power clutch on a 79 SC, don't recall any big difference in shifting effort.
1979 SC, Slant nose wide-body cab conversion. AEM Infinity EFI, COP, supercharged! |
1984-911 M491
I observed a notable improvement in throttle response.
1984-911 TLC......SOLD |
I have the Power clutch as well. I didn't notice a big difference in pedal effort. With a properly adjusted clutch cable you shouldn't have any issues.
Inspect your existing cable and replace if you see any wear marks or fraying. At the very least remove it and lubricate it so it moves freely in the housing.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
Changed over to the power clutch 5 yrs ago. If theres a difference, youll get used to it. Im pretty much street/city only.
Does seem a litte crisper and lets revs spin up slightly faster which is nice but also makes it tricky acclerating from a dead stop/stoplight on an incline sometimes. I would probably do the power clutch again.
Scott 1981 911SC Targa - Platinum Metallic |
