jedwards1123's Avatar
Setting Timing now speedo not working
Hi all,
I have a 83 SC 3.0 and after working on it this morning and now the Speedo doesn't work, i washed it, checked the timing, adjusting the gear shift coupler, but now the Speedo is registering nothing. I have clearly knocked or interrupted something.
Any suggestions?
Jeff
Jeff in sunny Western Australia
1971 Porsche 911T (under restoration)
1967 Mercedes 250SL Pagoda
2007 Mercedes SL350
2014 Audi A1 Sports
Old 12-18-2010, 08:38 PM
Senior Advisor
James Brown's Avatar
Adjusted the gear shift coupler!!!! go back and re plug in the wire that's lying at the bottom of the coupler access. That's the spedo pick-up wire.
08 Cayenne Turbo
Old 12-18-2010, 08:56 PM
Spot on James
Exactly right. I knew I must have bumped something somewhere and you were spot on James. I had knocked the connector in the tunnel.
Many thanks.
2007 Mercedes SL350
2014 Audi A1 Sports
Old 12-19-2010, 01:38 AM
