Where can I get this valve?
My Ambient Air Valve on my 85 Carrera recently went into the Kazoo mode. The AAR valve is the black thing in the top left of the photo. I searched the archives and the real solution was replace the valve. Of course that means an upgrade to the new style and that meant a new bracket as well.
Here is the original AAR valve and one way valve. The red arrow points to the one way valve. ![]() I figured "while I was in there" I would replace the short bent hose from the one way valve. I wanted to replace the one way valve that looks just like a standard PCV valve on most other cars. The valve is unavailable from Pelican or Porsche. I can't find one at all. The real purpose of this post is does anyone know of a replacement for the valve? It was obvoius to me it had never been serviced or replaced until now. Here are two photos of the valve and the rubber hose it fits into. ![]() ![]() I figure after 25 years it can't hurt to replace it. The check valve I want is part number 930-207-243-01-OEM .
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! Last edited by GH85Carrera; 12-23-2010 at 12:27 PM.. |
I am seeing the part as 930-207-229-00-OEM, which is also NLA.
Your PN came up as just the sleeve it sits in, or did I goof? Think a dealer would have some left over stock? "...Kazoo mode..." (that made he chuckle)
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue Last edited by steely; 12-23-2010 at 12:43 PM.. |
I asked my dealer, they did a search of the other dealers and even Germany. They came up empty.
Kazoo mode is what it sounds like. I got a LOT of smoke when the engine was cold in that mode. Once the engine was warm, the smoke went away. Pelican has it on this page: http://www.pelicanparts.com/cgi-bin/smart/more_info.cgi?pn=930-207-229-00-OEM&catalog_description=Check%20Valve%2C%20%20%39%31%3 1%20Carrera%20%28%31%39%38%34%2D%38%39%29%20 Part number 930 207 229 00 OEM
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! Last edited by GH85Carrera; 12-23-2010 at 01:18 PM.. |
It looks like a pcv valve. Maybe find one at the auto parts store that has the same dimensions?
Ed 1973.5 T |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Glen,
Would this work? eBay Item # 370463456531 Good luck, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Glen, what did you end up doing here? (14 years later)
SWB 912 - G50 Carrera - 986 Boxster - 997.2 911 Turbo - 958.2 Cayenne - 9Y3 Cayenne GTS SOLD: 958 Cayenne Turbo S - 997 Carrera 4S - 957 Cayenne Turbo Workshop Coordinator at Ehrlich Motorwerks instagram.com/patrickossenkop ehrlichmotorwerks.com |
The US SC's had this one:
https://www.pelicanparts.com/More_Info/93010728900.htm?pn=930-107-289-00-OEM Don't know if this will work on a Carrera...it's a throttle, no valve which enclose the connection... Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL. |
The purpose of the ambient air valve is to prevent freezing of the throttle body during cold weather starts. The part in question is a check valve to keep air flow to the ambient air valve in one direction. As I stated previously, I believe it is nothing more than a PCV valve and could be replaced by a new one of similar dimensions.
The part shown in the above link is a restrictor to maintain a certain vacuum in the later CIS intake when the oil cap was removed with the engine running. It would not prevent a reverse air flow. It was not needed in early CIS like my '73.5.
Ed 1973.5 T |
Flat Six
A while back someone else had this same question:
https://forums.pelicanparts.com/porsche-911-technical-forum/614095-pcv-3-2-does-she-need-teminate-how.html Dunno if this AutoZone valve is the right size, but looks close: https://www.autozone.com/emission-control-and-exhaust/performance-pcv-valve/p/spectre-pcv-valve-for-breather/266133_0_0 If you get it, let us know if it works.
Dale 1985 Carrera 3.2 -- SOLD 2026 Jaguar F-Pace / 2025 Ford Bronco Sport |
