Less brakes, more gas!
I'm re-working the whole suspension and ran into an issue... I bought these to swap out the Boge struts I had:
FS Bilstein Struts Cleaned up well and threw them in the car last month... but did not put the hubs on as I had a lot of other work to do and wanted the space free to get into the wheel well. So today I was planning on bolting the hubs on, doing ride height, corner balance, and align... Repacked the wheel bearings and... opps... outer bearings do not fit on the spindles!! WTF?? ![]() That is as far as the outer race goes on. So off to the Pelican catalog to see where I went wrong and how much it will cost me to correct my erroneous ways... but I 'm still confused: Pelican Parts - Automotive Parts and Accessories - Porsche & BMW I have the FAG bearing so I am assuming I need the SKF instead? But, it was assumptions that got me in this hole to begin with... What outer bearings do I need? Do I also have to replace the inner bearings? Do I have to replace the WHOLE hub?
Michael ![]() '82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah '13 Cayenne GTS |
sudo apt-get purge 930
That's as far as they go on. Hard to see in my pic but you can make it out.
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
Senior Advisor
There the same bearings, just different quality. Try putting the hub on the axle and reinstalling the bearing and seeing how close they are. That outer bearing should slide on smooth. Check to see if there are any burrs around the axle threads and clean them up. Also, try to screw the axle nut on and see if it goes on all the way without binding.
08 Cayenne Turbo |
edit. I just reread the first post and I am an idiot.
been there!
BINGO! there was a burr ever so small. Filed it off and the bearing slides on now. Thanks guys! I knew i was not completely fubarred!
Senior Advisor
Sounds like a cool project, let's see some more pics
08 Cayenne Turbo |
Any chance you could measure the spindle diameter and the bearing diameter and post the numbers?
Curious. >930 -78 3,3 front wheel ??
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
Ahh, Jeos
You are a smart cookie, mr"peepee flailing avatar" man.
Edit: Ah, just read that post. Mine and the 2 sets my friend measured were the same ~19.04mm depending on how you hold the calipers and I will not be ordering special bearings just to get rid of 0.01mm...
Michael ![]() '82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah '13 Cayenne GTS Last edited by euro911sc; 01-02-2011 at 10:12 PM.. |
hehehe never drink a fine wine before its time
I'll post a ton in a few days when everything is buttoned up. right now I'm just trying to get it road worthy ![]() Here are some teasers: Mnnnmmnnn fiber glass... adding lightness! ![]() Anyone guess what happened next? ![]() CV Grease is your friend... no really it stays with you for weeks after... ![]() Who can count the go fast bling in this pic? I see six items of fun! ![]() You just cant have enough wheels... Hi I'm Michael and I am a wheel whore ![]() ![]() ![]()
Senior Advisor
My guess is Crack, boingggg, kablammm!!
08 Cayenne Turbo |
Thanks for the numbers, Michael.
Close... you are missing the 'OOwwwww!!!! @#$%$#@$ #@$ $@ @#$' as one of those left a nice 1/2" 12 pt imprint on my fore head LOL no blood though so it doesn't really count as battle damage
Senior Advisor
A head shot, nice!
08 Cayenne Turbo |
