I think you said you had SSI's on it during the check.
If so, did they not pick up on in not having a CAT? Also, I believe a motor change (3.2 efi into a 3.0 CIS car) is a whole different fine tooth comb approval process. Be careful you do not get flagged for that to. I wonder if a C2 intercooler and turbo on a 3.2 Carrera would get noticed if the stock AFM / air cleaner were in place and a stock J pipe w 930 cat were in place? I used to take my Euro Turbo in on a first thing Sunday morning for smog test. My thought being the guy was more worried about getting through it first cup of copy than if the shop owner might get flagged. |
Thanks for all the help ... I'm going to meet with the smog guy Monday to try a creative approach - and then most likely will need to do the swap to original to actually pass.
>Did you buy the car near you? >Can you go to one of the stations from where it was previously tested? >Though, now that you are in the system.... I bought it in Sacramento and live in Mountain View, CA. ... >Finally just a question out of curiousity: Why are you retesting if the car >passed smog in April? Selling? It may be cheaper to sell with no smog or out >of state. Good question, the new registration demanded a new smog test, but it's clearly been less than a year. In hindsight I may have been able to just show the prior owners results from earlier this year. |
Burn the fire.
If that MAF had a C.A.R.B. approved number on it, you probably wouldn't be in this situation.
The problem is that CARB wants the car to be able to pass in 100% stock trim. The reality of the situation? They're slowly raising the standards so in 100% stock trim our cars will eventually be unable to pass. I have to echo the suggestions here... Borrow the stock AFM and ECU for your year engine. Swap it out for emissions testing. There are some around here that do that for other emissions equipment.
[x] Working | [_] Broken: 2017 Victory Octane [x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi "Drive it like you stole it." |
Now in 993 land ...
You can use any smog certificate if it is less than 90 days old, so April wouldn't have cut it. Good Luck, George |
No - the car has SSI's that came with it ... and I was just about to finally reinstall them on the car. Glad I was slow getting this done :-) >If so, did they not pick up on in not having a CAT? The guy did not even look - but at that point I'd already failed for the MAF |
warner53 - many thanks for the swap offer! Santa Rosa is a strech since I need to take the car back to the same shop :-(
stlrj - 100$ for the chip would be great. Let me quickly shop harder for the MAF and will get back with you if I find one used. I only have till Jan. 11th to get it fixed (slim chance given my work schedule). The state already sent me a "notice of bail". I will likely have to make a court appearance. I plan to try and use VC 27156 on the smog guy plus a letter for his files tomorrow morning. VC 27156 Prohibition Against Uncertified Vehicles and Devices (long shot) |
Wine User
Good luck nymble
I've missed the bullet. Registration stickers are in the mail!
I'd gotten a "notice of delinquent renewal", but had already paid the registration fees (two days before they were due). I called the DMV and after 3 attempts finally got into a phone queue to wait 20 minutes to talk to a human. The very nice DMV lady (rare) was very helpful and let me know that I was fully paid up. The delinquent notices are apparently send a day or two before the actual final due date. She noticed that the stickers had not been sent, and that I'd had a smog check performed when I purchased the car in April. The recent Dec. check was not necessary (in her opinion). The Dec smog check showed as a "T" and she wondered why it was not an "F" for fail ... and then went ahead and after filling out some forms issued the stickers. Whew. I can now go back to my slower repair/recondition schedule. A stock MAF will be in my shopping list :-) |
I am so glad I don't have to deal with Californication. Even here in lefty land Massachusetts anything older than 15 years old needs no smog test. Just drove my '82 in, lights, horn, tires, wipers and a good brake pedal and $29 and your good to go.
Same goes for my '92 Landcrusher! All othe cars only need a smog every other year. I tell ya they are trying to take all the old cars off the road, just like the cash for clunkers and buy back being proposed.
G. Hamilton '82 SC Guards Red-2nd time owned-Now sold "Bumerang" '70 TR6 N of Boston |
I'm glad you were able to kick the can down the road another year or two BUT , as some have alluded to above, you have a 3.2 in an SC. CA requires that a newer engine installed in an earlier car be inspected by a referee station and to have a BAR sticker issued.
I would be careful about getting involved with any referee station unless it is your intention to have the car BAR certified to the newer engine. The ref's look at the engine serial number to determine what emissions equipment is required to be installed. They will not pass you unless the 3.2 is stock and has all emissions related equipment in place including the evaporative fuel tank venting system. My advice for next time would be to put the stock equipment back on and just take it to your local smog test station and play dumb. If you get hassled again you will have to take it to a referee and get a sticker. Then you are good to go and can get subsequent checks done at any smog check station. I have a 3.2 in my 77 911s and went through this process. It was not a big deal and now the car passes its bi-annual inspections easily. Keep an eye out here on pelican for the parts you need. You should be able to find them very reasonably if you're not in a hurry. Good luck! |
Final update on MAF - till next smog check
Very late putting final update on this thread - but:
1) talked DMV into skipping this smog test (since the car was new - this is earlier in discussion) 2) Went back to the smog place that it failed and got them to give me a "pass" by giving them a letter from a automotive parts company saying that the MAF did not increase emissions (company was "Nymble Works"). THe smog shop just wanted to have something on record 3) Just this month had the MAF cleaned up - pictures below, assuming this will help next time - but I plan to take it to the same shop again in two years :-) Before picture of MAF ![]() After picture - MAF on back side and wireing cleaned up (thanks to Marvin at Rennshop) ![]() |
Here's what I would do:
A: Get rid of that "cone" the next time you take it in for smog. Will a stock air cleaner fit? B: Install a (gutted) stock MAF in place of the obvious hole(s) you have, run a fake wiring harness to it. C: Rent, borrow or steal a hot blonde with big knockers and bring her with you to the next smog appointment. Insist she stay seated in the passenger seat during the test... ![]() If the above doesn't work, I will pay for your re-test. Last edited by Danny_Ocean; 06-21-2011 at 06:30 AM.. |
CA will fail almost any type of mod. e.g. if you install a LS3? V8 and have all the same parts but the exhaust manifold points a different direction relative to the engine you may fail. Borrow parts and retest and then go back after passing, but you will need to do this again in 2 years. Caveat emptor case in point.
To start with......
I'd take the sticker off of the MAF. Dead giveaway! If possible, find/make a sticker that matches what would be on the Porsche unit. If there is no lable on the Porsche unit, leave it blank. That along with the correct air filter should make it look "stock" enough to get by, especially since it is running clean. I would also not go back to the same testing station so that there would be no "oh, yeah, I remember you" syndrome. Ask around to see if there is a particular testing location that is more favorable to cars such as your Porsche. Good luck! All this is yet another reason that I live in Georgia rather than Kalifornia!
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
If you wanted to be a hard a$$ ask the PO and smog check station to supply the required parts or you would like to return the car. In CA it is the sellers responsibility to provide the car for sale in smog passing condition or is it just that it passed a smog check. I wonder what a court would say. The PO and/or smog check station owner could just say, when it was sold the original equip. was there.
The point is in my opinion the car was represented as able to pass a correctly administered smog check. It was sold to you in a condition that will not pass a correctly conducted smog check. If anything can be done or is wanted to be done regarding this is another issue.
Thread Tools | |
Rate This Thread | |
Tags |
smog 911 maf air |
