Dry cell battery recommendation
I´m in the middle of a suspension pan replacement project. I´m thinking on getting one of those fancy drycell batteries (Optima). Don´t want to deal with rust in the battery area any more. This is the old battery info (66Ah, 510 A).
Locally I found an Optima red top, model SC75U, CA 910,CCA 720, RC 90. Is this battery OK for my car (911 carrera, year 1985)? Using the forum search tool I found recommendations for a different model of Red top Optima battery (34U or 75/35). Thanks Miguel |
Banned but not out, yet..
Why not ask Optima? Import Car Performance: Ask The Pro Look for Ask a Pro and send an e-mail
FWIW: I use a Red Top which I bought at Costo and it is fantastic. No worries about battery acid.
An air cooled refrigerator. ‘Mein Teil’ |
Look at Braille batteries. Much smaller and lighter than the clunky Optima. Same advantages.
jhtaylor santa barbara 74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's. 73 Targa (gone but not forgotten) |
Deka manufactures the batteries for Braille and sells them for close to half the cost. I replaced my interstate and saved over 20 lbs in front.
They are a glassmat battery similar to Optima & Oddesy. Do a google search. There is an outfit out of Florida, family business and they will set you straight on which is best for your app...
joe ------------------ '69 911 E Targa - aka "RoxiE" |
I'm very happy with the Odyssey batteries.
'78 911SC Targa (SCWDP member #17) '74 MGB (one owner) Pickup 2013 Ford Explorer Sport 2013 VW Golf TDI |
There are alot of battery choices out there but the optima red top is readily available and does a great job. You might have to make a little adaptor out of a plastic cutting board but it fits great. If you do a search here there is a template. With some cars they bolt right in. In my 91 it fit in the original mounting plate , on my 73 it was a bit trickier, your 85 might be a straight exchange.
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
Max Sluiter
Lithium.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Anyway, i went with Braille B2317 (17 lbs, 472 CCA), cost was $166, including the battery clamp you see below, from Jegs. I went with it based on one Pelican's recommendation, he said he had it over a year and it worked fine. I have started my car exactly one time with the new battery because I had to build a battery holder for it. That's what I did over the TG holiday. ![]() Now I need to install it. The plate is 5 x 13 x 3/16. One end will wedge into the 5" wide slot where the rear of the battery goes, and on the other end I will drill a hole to be able to use the normal tie down bolt. I put 3/8" dense foam tape (such as you see between the battery and the channel) on the bottom of the plate to protect the paint. |
i used to swear by optima batteries but their quality, imho, has gone down considerably in the last few years but their prices have gone up. i prefer kinetik batteries simply based on my own experiences, which have all been stellar. i replaced the giant old lead-acid diehard in my SC with an hc800 and i have been very happy.
another battery install thread
- He gave his father "the talk" - Once while sailing around the world he found a shortcut - He taught a german shepard how to bark in spanish He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends. |
Max Sluiter
I pound for F1: Braille Battery USA - MLF1T
This one looks more like 911 size. 6 pounds. Braille Battery USA - ML20C $1500 ![]() This one is only $950 and 4 pounds. http://www.braillebattery.com/index.php/batteries/ml9c/ Good for racecars with nothing but the starter to run.
Stressed Member
See here: Poor Man's Lightweight Battery
I've had one of these for a couple of years now. As long as it's above about 35 degrees it works just great. I keep in on a battery tender during the winter, as I don't drive my car daily. I've got mine mounted in the stock battery box of my '70E, driver's side. Fits with room to spare. Cheap. Light. Effective. Inconspicuous. It cranks a 2.5SS with 9.7:1 CR, using a gear reduction starter. I think I paid about $70 for mine, including shipping.
'70 911E short stroke 2.5 MFI. Sold ![]() ![]() ![]() '56 Cliff May Prefab |
'73 911 T Targa
Lifeline makes AGM batteries in in a variety of sizes. I have seveal and I am very pleased.
battery
Many plusses for Deka - this is one Steve Wong recommended - 11#
Bob |
Do you know the model number?
1997 C4S stock...ish 1970 911T Restored Hot Rod....Sold ![]() http://forums.pelicanparts.com/porsche-911-technical-forum/418411-here-my-new-old-project-lilly.html |
lightweight battery
hi together, go to pff.de and find the following thread
Leichtbau-LITHIUM-StarterBatterien - hier gibt´s die Antworten they are between € 250.- and 400.- they are working fine. 20 ah about 3 kg 40 ah little more |
Battery
The Deka is Extreme Sports/ ETX 14 - We made a cradle for it, mounts really clean. I paid $76.00 plus tax for battery.
Bob |
We used to use Optima but the quality isnt the same as the older product. We now use Kenetic batteries at the shop. Very efficient batteries. They charge in no time and dont hold a memory like others. A little more money though.
Decode it.
I replaced my 3 year old Optima red-top this summer with a new one.
Four weeks ago I forgot to plug my car into the trickle charger and now the new Optima will not charge. Now I'm pissed and will be going with something else. jetstar: What Kenetic battery is suitable for a daily driver 911?
'88 Porsche 911 Coupe - Venetian Blau ║ '78 Mustard FJ40 "Uglina" ║ '87 BMW 529i "Maytag" ║ '87 BMW 535is "Vlad" ║ '85 BMW 528i S54 "Minerva"
Don't give up on the battery just yet. it might not be charging due to the charger not the battery. Read up a bit on chargers and be sure you have a charger that can see and start a charge on a dead jell cell plate battery. Some chargers see a discharged jell cell as a short. Some batteries need to be conditioned prior to recharging if they go below a certain % of charge.
see my post above. i run an hc800 in my 83SC.
