How do you perform a leak-down test?
Ok, I am armed with my newly acquired compression guage and want to do a leak down test along with my compression test. I searched the archives but can't figure out how to do it. It is probably pretty simple and I'll feel pretty dumb, but how do you do a leak down test? Is it best to do it while the engine is warm or cold? Step by step instruction are appreciated.
Old 01-29-2002, 04:07 PM
a leakdown tester is needed. starting on #1 cylinder, at TDC, engine warm, the tester is connected to the short hose that screws into the plug hole and what reads on the gauge is the percentage of leakage from 0 to 100.( the tester is pressurized at about 90# from the shop compressor). then turn the engine clockwise 1/3rd turn to TDC for the next cylinder in the firing order (6) and repeat, etc. any high readings should be taken with a grain of salt until the engine is run again and that cylinder retested. (potential for a bit of carbon to cause the high leakage).
206 637 4071
Old 01-29-2002, 04:39 PM
Thanks JW, now if I could find an inexpensive tester.
Old 01-29-2002, 05:03 PM
boyo's Avatar
A trick from the Old Chevy Truck guys I know for figuring out if a low compression cylinder is due to rings or valves...
Do a compression test on a cylinder, then remove the spark plug and squirt some oil in there. Then run the compression test again.
If the compression goes up, your rings are shot. If it's about the same, your valves are shot.
Of course, how do you squirt oil into a 911 cylinder?
-Boyo
'48 Willys CJ-2A / '55.1 Chevy 3600 / '66 Austin-Healey 3000 / '72 Porsche 911T
Old 01-29-2002, 05:20 PM
In case anyone else is wondering, a DIY leak down tester. Ask the internet and you shall receive.
http://www.xs11.com/tips/misc/misc3.shtml
Old 01-29-2002, 05:29 PM
Senior Member
Superman's Avatar
Leakdown test numbers are not particularly reliable, so I believe half the value is in listening to where the air is going. Just pressurize the cylinder and listen. Hissing in the crankcase means the air is getting past the rings. I am told all cylinders always hiss, so expect that. You can hear them by taking the oil tank cap off.
Valves on the other hand, are NOT supposed to leak. Take some exhaust pieces off to listen to exhaust vaalves, and take you air filter off and open the throttle plate to hear the intake valves.
This helps isolate problems suggested by the compression test.
Mocha 1978 911SC. "Coco"
Old 01-29-2002, 07:15 PM
Senior Member
Hello
Mildon had a very good priced unit in the 90´s ( just pick a US V8 magazine like; CarCraft, HotChevy, HotRod, AutoBuff and go trough there adds )
Grüsse
Old 01-29-2002, 11:17 PM
rob911's Avatar
Hell you can even make your own compressor - top DIY guy
http://facstaff.uww.edu/fieldsj/mcycle/Comp/
01 Maserati 3200 GT Assetto Corsa
84 3.2 cabrio - gleaming
99 Alfa Romeo 166 3.0 V6 super - still going
03 Fiat Punto 1.2
http://www.pelicanparts.com/gallery/rob911
Old 01-30-2002, 02:57 AM
T Bird's Avatar
PBS911
If you're not up to making your own, you can buy a leakdown tester from Eastwood for under $50. Check out this link.
http://www.eastwoodco.com/cgi-bin/sgsh0101.exe?AID=43625&FNM=20&PID=12778&SKW=leakdown&UID=%21%2BUSID%21
Good luck.
John
1972 911T Coupe
PCA- Potomac Region
Old 01-30-2002, 04:57 AM
Senior Member
Hello
Good leak down testers show the actuall flowing volume and you have charts from new rebuild engines to compare.
In fact every engine has a other flow level depending on the diameter from the piston, compression ring design and for special cases ( backside messuring if the heads are off or the valves leak or just to go sure if the spark plug hole isn´t thight ) how much pistons are in the engine. Technical seen you can add up all the borderlines and look at the engine as one big piston.
However the %-tage scale on most versions is accurate enough.
The interessting thing on leak down tests is how will it show up when you cycle the engine. F.E: if you have a flow rise during the stroke up to ITDC* the liners are worn. If they are at LDC your piston skirt is worn out and the pistion will flip over while duration witch leads to not proper seatet rings. ( However if the engine is runing and the masses are oszilating that doesn´t affect that much ).
If you are used with the stuff you don´t need a instrument. You just need a hose and your finger ( thump ) on the hose. You run it up into compressionstroke and you will feel the pressure and hear if & where it blows by. Thats my short check on used car lots .
I never trust compression diagrams even not my own ones ;D
However most people like to see numbers and like to sort things into tidy charts. Most will dump good race engines due the low compression. ( Einstein; Everything is relativ )
Grüsse
*( ITDC = Ignition top dead cycle LDC lower dead cycle sorry miss the correct shortterms )
Old 01-30-2002, 02:56 PM
Author of "101 Projects"
Wayne 962's Avatar
Someone mentioned earlier doing the test when the engine is warm. If you remove the spark plugs when the engine is *very* warm, then you can gall the heads and damage your spark plug holes. BE VERY CAREFULL. Use a 1/4" ratchet...
-Wayne
Old 01-30-2002, 03:16 PM
...... and a small dab of antiseize on the spark plug threads. This helps prevent future galling and metal-to-metal fusion.
Sherwood Lee
http://members.rennlist.org/911pcars
Old 01-30-2002, 03:27 PM
jkeyzer's Avatar
At the risk of straying OT with this, I have heard that antisieze should NOT be used on plugs. It might have even been on this BBS. I'm not sure which to believe. Sherwood?
Jeff Keyzer
72 914 w/2056 built by Mark DeBernardi @ Original Customs
Megasquirt with MSII upgrade
Old 01-30-2002, 05:12 PM
to each his own on the antiseize thing. years ago, porsche put out a bulletin suggesting it not be used. i'll try and find the bulletin.
206 637 4071
Old 01-30-2002, 05:52 PM
Senior Member
Doug Zielke's Avatar
So John, what do you think their reason might be?
Are they concerned a well lubed plug may back out of the hole?
I have always used Anti-Seize on plug threads, especially m/c engines which seem to have very soft alloy in the cyl head.
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 01-30-2002, 06:13 PM
Senior Member
Hello
JW statet that. There is a difference between warm and hot.
When you finished the test the engines are mostly "cold" again.
Also the leak down is one step to find problems and sometimes you have the valve covers removed or other parts are off.
However a bit sensitivness is always asked if you work on aluminium engeins. They just can´t "handle" the same care a ols iron will need to keep runing. I know mechanics who use power tools to change the plugs.
Grüsse
Old 01-30-2002, 11:16 PM
personally, i think the bulletin was to warn against too much compound on the plugs. people use things other than antiseize, and i've pulled plugs out that were very difficult to remove because of copious quantities of baked on goop. if you're going to use it, just a minute amount is all you need. nothing that would collect under the seating surface as the plug was screwed in.
206 637 4071
Old 01-31-2002, 08:12 AM
Question
Loctite makes an anti-sieze Graphite-50 that is good to 900deg. F. Any info on this?? Has 2X the conductivity as copper anti-sieze. Wonder if 900deg F is good enough for spark plugs??
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-31-2002, 08:20 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Since we're off topic.... and Roland and John covered the leakdown issue......
RoninLB,
Here's another source for the nickel-based anti-seize you posted about before (if you're still interested).
Permatex Brand
Anybody got specific uses for the different types of anti-seize?
Kevin L
'86 Carrera "Larry"
Old 01-31-2002, 10:48 AM
Cool
KTL---I found the nickel anti-sieze. Great with allum/mag metals, good for 2400 deg F [I think,can in garage] Iwant to use the nickel on exhaust system. But the nickel doesn't have the conductivity of Loctite Graphite-50. I want to use it on ground straps, etc.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-31-2002, 02:25 PM
