faverymi's Avatar
Threaded/Snapped drop link???
Looked for post, couldn't find anything.
Is there a way to replace the prior 77 snapped rear sway bar drop link for the more modern bolted one?
Ultimately I would like to install the adjustable links
Thank you
Old 01-16-2011, 09:52 AM
Max Sluiter
Flieger's Avatar
You are using the ball on the trailing arm?
Most aftermarket anti-sway bars with the adjustable drop links use an attachment on the spring plate, using a special bolt.
Would your current sway bar work with that geometry? You can buy the drop links separately.
Suspension2
Old 01-16-2011, 11:22 AM
faverymi's Avatar
I'm planning on redoing all the bushings in the suspension.
I just never liked the ball attachment. I think must be a reason why they changed it on the SC.
Anyway. It is completely stock. I do have some newer sway bars that have the later drop link.
I'm just wondering what to do with the ball on the trailing arm. I want to get rid of it if possible.
Old 01-16-2011, 12:16 PM
Max Sluiter
Flieger's Avatar
If you are not using it, just leave it there. My steel trailing arms still have the balls, even though the anti-sway bars are using the spring plate bolts.
If you are concerned about the weight or something, cut it off with a mill.
Old 01-16-2011, 05:36 PM
faverymi's Avatar
Super, thank you.
Old 01-17-2011, 07:01 AM
