Oil consumption and engine health
I searched but couldn't find a thread related to my question. Can someone give me a run down of oil consumption in the SC and 3.2 as it relates to engine condition? I guess the easy answer is that the more it uses the closer it is to needing major work. How the car is driven would also have an effect.
As a prospective buyer, how will I know how much a car uses? (without having to rely on an owner's word...not talking about you, Jerry! I believe your car is mechanically sound!) The one car I test drove didn't smoke upon start up. After about a 20 min. drive, I held my hand up to the exhaust with the car idling and saw nothing unusual. The tail pipe smelled of warm metal. I'm just trying to figure out how much oil consumption is acceptable and a way to weed out the ones on their last legs before spending $$ on a PPI. |
Member 911 Anonymous
1qt every 1k miles per owners manual
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
muck-raker
unfortunately, the best way to find out is the PPI, including a leakdown test. The next best way, and less expensive, is to do a compression test yourself.
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
Mo money = mo parts
+1 on 1 QT per 1k miles at the lower end.
I would do a leak down and compression, but a leak down won't always reveal higher oil consumption. The valves are closed on a leak down test, so it will tell you that they are seated. It won't necessarily tell you if the guides and/or seals are bad. A PPI by a wrench experienced with air-cooled can pull the covers and tell you if there is excessive lateral movement in the valves - an indication of guide wear/condition. Actual records will provide the best evidence of oil consumption, but understand your dilemma as a prospective buyer. If I were in the market again, knowing what I know, this is what I would do. I would have the car parked for 24 hours, then be present to start. If there is no oil puff, it's a good indication the valve seals are in good condition. I redid my motor last winter and could park the car for a day, week, etc and no even the smallest puff. A puff doesn't mean it's bad, but probably take one more step - make that do this no matter what. Take a friend with you, let him drive the car. You follow in yours. When the car is warm, signal him to go to full throttle up to 5k, then let off the gas. If you see a lot of lot of soot coming from the exhaust, then I would be more concerned. There is no full proof method, but if you have someone qualified pull the valve covers, get good compression and leak down, plus no visual evidence in your start and deceleration tests, you should have a lower risk of high oil consumption
Greg 86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten 65 Ducati Monza 250 & 66 Monza Junior (project) "if you are lucky enough to own a Porsche, you are lucky enough" |
"When the car is warm, signal him to go to full throttle up to 5k, then let off the gas."
I was told that this helps to show if the valve guides are worn. A leak down test won't do this. Also an oil analysis can show if there is an unusally high amount of bearing material in the oil (lead, tin, copper...). |
The two visual signs of high oil consumption are: 1) smoke out the exhaust and 2) oil on the spark plugs.
I would recommend that you do PPI at a shop that knows the air cooled engines. If you mention where you are, we might be able to recommend a shop. A proper PPI should include doing a leak down test. To do a proper leak down, you will need to get the engine to operating temperature. During warm-up of the engine, you can blip the throttle as suggested above, and look for smoke. If it passes that test, then go through with the PPI, and ask the tech to cover inspection of the spark plugs with you. |
Actually, the owners' manual (at least for my '86 targa) says one litre/1000 kms which is a lot more than a one quart/1000 miles.
1986 Targa 1968 MGB (2) |
The suggestion above, to follow the car and with the engine warm hold the engine at 4-5K revs for a city block, then decel by removing your foot from the gas, is excellent. I've done this a hundred times, and it removes some of the pressure to get an honest answer from a seller (and sometimes a seller doesn't honestly know).
Keep the Shiny Side UP! Pete Z. |
JCFL
Location: Caraquet, New Brunswick, in eastern Canada (600 miles east of Boston)
I had a 3.2 that did 1 quart per 5000 miles
I am now driving my second Porsche, a 1982 SC, which I've had for one year. Previously, I had a 1984 Carrera with a 3.2 engine. I am by no mean an expert, not at all.
But I can report that my 1984 3.2 had been rebuilt several years prior to my buying it by an expert Porsche mechanic. He must have done an excellent job, because through about 20,000 miles of driving, I averaged about 4300 to 4800 miles per quart. I once called PCA expert to verify if there was with my engine because of such low oil consumption. He said that I was one of the lucky ones, with such great mileage. My current Porsche, 1982 SC, has 135, miles on the engine. Last summer, I drove 13,000 miles over 6 months, and my average was about 1 quart of oil per 1600 to 1900 miles driven. Good luck. JCFL |
Why do you think Porsche specified 600 miles/quart? Would your engine really be OK if it was using that much oil?
Thanks for all the replies.
I live north of Seattle so there are many good air-cooled shops down there. Does it make sense to have a PPI done at a shop where the car is currently serviced? Last edited by BKC; 01-19-2011 at 05:55 PM.. |
N-Gruppe doesn't exist
JW is a very honest wrench. if it is one of his regular customers he should be able to give you a good low down on the car in question. he would know details about the engines history the owner may not be willing to divulge
Ted '70 911T 3.0L "SKIPPY" R-Gruppe #477 '73 914 2.0L SOLD bye bye "lil SMOKEY" ![]() "Silence is Golden, but duct tape is SILVER.” other flat fours:'77 VWBus 2.0L & 2002 ImprezaTS 2.5L |
If you see 1000-1500 miles/quart you are in a comfortable Range. When I got my car, it was at 600 miles/quart. FWIW, worn valves guides can be very dramatic. My car at 300 miles/quart, as I lift off the accelerator:
Coincidently, a car I'm interested in is maintained by John Walker!
All air cool engines in nature consume more oil than water cooled engines. Check out someone that owns one. You will find a qt of oil in the door pockets another in the trunk. I believe that air cool engine in design alone having more gap between piston and cylinder liners due to expansion and contraction under heat conditions contributes significantly.
1986 Porsche Carrera ![]() 1997 Porsche Boxster (Sold) :0 1995 911 Cabriolet (Sold) ![]() 1971 Porsche Targa 911E (Sold)
My car has 90K miles on it (and hasn't been opened up) and does about 3000 miles to the quart, but oddly, when I gear down to pass (I'm told by other tour members) there is a puff of smoke. Since I haven't actually seen it, I don't know what it LOOKS like. I guess it can't be much, considering the miles that I do between quarts. These are potentially very long-lived engines, on a tour last year I ran into a guy (with a 3.2) with 280k miles that had yet to be opened....no valves, guides.... yet, amazing. He had it for the last 100K miles and I can tell you he didn't baby her at all. Cheers
