Does anyone know where I can get artwork of the "Carrera" script as used on the sides of the 1973 Carrera RS? Smaller-scale would be preferred. I know the decals are comercially availible, but I have something else in mind...
Platinum Member
I have them scanned in for a 'vinyl cutter', but it uses its own file format. What size do you need?
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
Bird. It's the word...
Dad, can your "carrera script" file be sent via net or floppy/disc? I've been thinking about getting the script for my car, but was considering another colour combination other than what is available from factory. Is this possible with the vinyl cutter file?
Cheers
John Forcier Current: 68L 2.0 Hotrod - build underway |
Hey, dad...
I would take it in waht ever file you have. Could that file be emailed? If yes, strahota@optonline.net ds |
Platinum Member
I saved it as a dxf. Let me know if this works. (zip file attached)
Carrera Script
Hi downloaded and opened the DXF file though nothing happened.
Does anyone have a carrera script saved as a font or some other format? Both earlier styles I am looking for. thanks Michel |
Formerly known as Syzygy
If you have it in .dxf, you should be able to export to a .eps. This is a vector file that will be useable by any sign cutter or designer. It's pretty universal.
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. |
R&D guy
Location: the border between the states of inebriation & confusion
dad911 -
Thanks for posting the .dxf file. I've seen this in .bmp, jpeg, etc., but not in a standard file exchange cad format. Very helpful for scaling, and even extruding to 3d using standard cad s/w. Again, thanks. |
Platinum Member
Your welcome. Old thread.......
dw1, do I know you? NNJR? |
Is that font available? I'd like use the same font to spell something different.
Thanks |
