Is there something wrong with the rear of my cab?
I have asked this before, but not sure I have ever got closure. I am posting some pics of my 1983 cab. No known wrecks and did not show up on vehicle history either. I have always found it a bit odd the way my rear pax side wheel/tire sit in the wheel well. Almost like it needs a spacer and less neg camber to look right - and yes, no spacer on the other - I actually checked to make sure I did not miss something stupid.
![]() Any ideas? (please excuse mess in the garage )![]() ![]() ![]() ![]() ![]() ![]() ![]()
Shane - 1984 928S |
RETIRED
Well yer pics suck, and your need to clean the garage.....
![]() Have you checked to see if the wheels are the same width? Has it ever been aligned? PS, use a tripod or take the pics BEFORE drinking or doing bong hits.....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
you kill me sometimes Mike. Yeah, I suck at pictures.
Wheels should be same width, unless one of my buddies in messing with me. It could use an alignment, been a little over a year, but not a lot of driving this past year.
Shane - 1984 928S |
RETIRED
Pull the wheels and check the numbers on the inside.....good chance there is a mix up. How do the fronts look? My 83 came with 16x6s and 7s.
You never know, maybe one of the rears is a 951 offsett? The PO coulda whacked one of the wheels and wasn't specific when he bought a replacement. 944/951 wheels are inset more inboard that 911 wheels. The early 911 crowd likes them so they can stuff a bigger tire under the narrow fenders. Now go clean the garage....
now you sound like my wife
Shane - 1984 928S |
RETIRED
20 years of being biiitched at, I have experience. Since the divorce, I don't miss the noise, just all my stuff....and my house....
On my 914, I had a 3/4 diff on side to side on the rears....common problem with them, I just put a spacer on one side.
Member 911 Anonymous
+1 on adding a spacer if it bothers you.
I added 1/4" spacer on the passenger rear to optically satisfy me. I had to add longer lug studs. Take care if you ever have to use the colapsable spare the longer studs will punch thru the lugs. BTW, I am feeling sea sick looking at those pics ;D
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
