Oil Level Sender Open Circuit Test
If I take a clip lead (aka alligator clips attached by a wire) and jump the pos (+) and ground (-) bolts on my oil-level sender visible by peering into the wheel well, while the sender is still mounted on the car and its two wires are still connected (in other words just reaching in there and connecting the clip lead), should the Oil gauge peg on low (in other words where it is where the ignition is off)? And if it does do that, can I assume the Oil level sender is faulty if it is always otherwise pegged on high when the ignition is in the on the position (irrespective of how much little oil is in the oil de-foaming box)?
I *think* high resistance means oil is full. If I recall, the resistance varies from 0 to 2K to ground.
The "+" connector is held on by a rivet, which holds another connector internally. Both sandwich a plastic insulator / sealer. So you have the spade lug to the rivet, and the rivet to the loop connector inside. On mine, those areas had oxidized and made an open / high resistance circuit. I took the whole mess apart, cleaned & sanded everything, and reassembled with a 3mm bolt & nylock nut & red loctite (you do NOT want a stray nut in the oil tank - the oil pump is just a big rubber hose away). I used permatex in an attempt to seal everything - no long term guarantees on that ...
'88 Coupe Lagoon Green "D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen" "We must not allow a Mineshaft Gap!" |
Senior Advisor
Oh the woes of the oil qty. sender. Valiant effort Burger but I just abandoned the whole thing and had Palo Alto Speedometer send me a volt meter to put in place of the oil gage in the dash. I check it every week (the oil) so I always know what to expect to find. It is a silly system, can you imagine if they were in toyotas?
08 Cayenne Turbo |
83 911 Production Cab #10
+1, just as about useless as tits on a bull. Check the dipstick after every ride before garaging the car.
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Senior Advisor
No but I have to figure out that if the pointer is pointing to 14 it is volts and not oil quarts or liters. It does require some knowledge of what the hell is going on with the instruments. If you need it than yes PAS can offer a VOLT sticker to match the gage.
08 Cayenne Turbo |
