Testing for WOT
So i put in the Steve Wong chip and am going through the testing for WOT. I unplugged the Full throttle micro switch and ran my leads to the top 2 connections 3 and 18 on the switch and crack the throttle and nothing is reading on the meter. From what i have read there should be a reading once the throttle is opened after about 1/4 open. Also when i have my wife steps on the gas pedal in the car i can still rotate the throttle on the throttle body about a half inch. Here are my questions,
1 Will the engine run rich if the Full throttle micro switch is not engaging?
2 Should the throttle get adjusted so that the throttle lever almost hits the throttle body? How close should i adjust the throttle linkage?
Rob
Old 01-30-2011, 03:57 PM
porsher
aston@ultrasw.c's Avatar
the WOT switch closes at about 3/4 throttle
for WOT the lever must contact the stop on the throttle body, anything less is less.
86 911 Race Car, with a few 993 bits in the boiler room
79 928 Race Car
88 928 Becoming a Race Car
Old 01-31-2011, 07:19 AM
Formerly known as Syzygy
Canada Kev's Avatar
I think the lever must ALMOST contact the stop on the throttle body. About a sixteenth of an inch or so kind of almost - really small, regardless...
Kevin
Old 01-31-2011, 07:55 AM
Thank you for your help. I just want too dig into this great car of mine and fine tune it.
Old 01-31-2011, 08:58 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Item 2 Definitely a Must for Full Benefit from SW Chip.
'85 Carrera Targa
PCA/POC
Old 01-31-2011, 09:02 PM
Well i will try it out tomorrow. I will adjust the linkage under the car first and then try rotating the switch to see if it opens at 3/4 throttle.
Old 01-31-2011, 09:33 PM
