5String
Turn-signal Relay
Hey, can anybody tell me where the turn-signal relay is located on an '82 SC? I think I may have a problem there, as I'm getting the following symptoms:
The blinker indicator in the speedo works as it should; Or it doesn't work at all; Or the signal arrows light, but very dimly; Or the signals both light at the same time, but don't blink. This just came a few days ago and I haven't messed with the electrics on the car at all. Thoughts? Thanks in advance - 5String
5String Tell not a soul that you have seen me; breathe not a word of what I say.... The Northwest Files |
abides.
IIRC, it's in the front trunk, down in the very back corner near the drivers side hood strut.
Graham 1984 Carrera Targa |
The relay is located in the trunk, under the cowl, just forward of the gas gauge. Easiest access is to remove the gauge and simply reach through the opening.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
I've got the same problem with my '78.
Did you ever get it fixed? What was the problem? thanks |
