Retired Member
Charlie V's Avatar
No Spark
I think I screwed things up here.....working on a 1977 911 targa for a friend.
I now have no spark at the plugs.
I was doing a little wire replacement in the engine bay. I screwed up and accidentally grounded the 12 volt wire to the distributor (long story why).
Would this fry the permatune box??
1982 911 SC Targa - Rosie....my Mistress. Rosewood Metallic on Dark Brown and Black. Long distance road warrior and canyon carver. A few mods - a little interior, some brakes, most suspension and all of the engine.
Old 02-04-2011, 07:26 PM
Burn the fire.
Brando's Avatar
Did you get some fancy Bosch wire smoke?
1) Check your fuses in the engine bay.
2) Check your fuses up front.
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 02-04-2011, 08:03 PM
I wouldn't think this would damage the Permatune. It should blow the fuse feeding the 12 volt wire. You can check the igniton system by making sure the permatune box has power and then gounding and ungrounding the points wire. It should spark when the wire is removed from ground. If no spark and you are sure of all the connections (power, ground, coil wires), then you have a bad permatune box or a bad coil.
-Andy
Old 02-04-2011, 08:27 PM
Retired Member
Charlie V's Avatar
-Andy
Thanks.
Old 02-04-2011, 10:51 PM
