you see Arthur...
jasonlee's Avatar
H4 lights need help
My 82Sc has Bosch H4, so i thought i would upgrade the bulls, bought bulbs from the local parts store, removed the light and found this.
The bulls I bought are 9003/H4, although I am not sure what to do next. Can I just remove everything and put the new bulbs in. Any help would be appreciated.
Thanks,
J
82 911 SC, Cat bypass, Flowmaster 1 in 2 out lightweight flywheel and backdated heat
06 Cayenne S
00 ML 55 AMG
Santa Cruz Bullit
Old 02-12-2011, 02:35 PM
Looks to me like someone put an H4 glass on an H1 headlight. Take the old bulbs out and see if they are not H1 bulbs. They have little clips that hold the bases in, leave everything else alone.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 02-12-2011, 03:16 PM
you see Arthur...
jasonlee's Avatar
they do indeed have a small clip on them holding a small bulb. Does that mean H1? Can I retro them to use the H4 bulb?
J
06 Cayenne S
00 ML 55 AMG
Santa Cruz Bullit
Old 02-12-2011, 03:21 PM
No you need to use an 2 H1 bulbs. One high one low. It has a different base . You won't get the best light with the H4 glass, but H1 glass is pretty hard to get.
1991 C2 Turbo
Old 02-12-2011, 03:27 PM
you see Arthur...
jasonlee's Avatar
thanks, so I guess its back to the store for bulbs.
Thanks so much for the help. It does lead to another question, why would I have H1 lights in an 82 SC?
J
06 Cayenne S
00 ML 55 AMG
Santa Cruz Bullit
Old 02-12-2011, 03:39 PM
Probably a retro-fit. H1s by most accounts are favored over H4s because of the ability to aim high and low beam separately as well as use separate bulbs of varying wattage. Even with the wrong lens, I'd consider it a pleasant surprise to have H1 lights, not to mention the difference in their cost over H4's. Your lights look to be in pretty good shape but be careful as parts are unobtainable, outside of the lenses. Don't bugger up the adjusting screws, and clean up that spring flex connector so it doesn't break from rust and maybe put some lube on the threads in the area of the adjusting pins.
There was a recent thread about the improper lens and the resultant lighting. The proper lens will give the optimum brightness/focus for the bulbs, but even the H4 lens will be adequate in regular night driving conditions.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 02-12-2011, 06:34 PM
