Whale tail rattle problem
Anyone ever have the mesh screen inside their whale tail come loose? One side of mine came loose and rattles when driving, this gets on my nerves like you would not believe. What is the best way to fix it? I tried looking for any type of screws to get into the tail but I cannot find any, am I missing something?
a.k.a. G-man
Yes you are missing the screws...
They should be there, if they are not, maybe that's why the mesh is rattling...
Сидеть, ложь, Переворачиваться |
where should they go?
a.k.a. G-man
What year is your car? Got pics of the tail??
If you look on the inside it should be clear where the screws go. I'm looking for pics of the one I rebuilt a while back, if I can't find them, I'll try to take other ones (tomorrow)
I have an 86, thanks for looking for me! I greatly appreciate it!
a.k.a. G-man
Found them, quality's not great, but I've marked the locations in red.
There could be more that are not visible on the pictures so it's best to have a good look in there to see where there might be more... Top side, had the part with the louvres painted, RS America style. (I still have another that is stock) ![]() Inside view ![]() inside view with locations marked
Member 911 Anonymous
Take care, it is very heavy and watch the screws don't drop into the engine bay.
Once off you will notice the most or all screws are loose. Do not over torque you may fracture the tail housing where it holds the mounts. I hated it when it vibrated when I play my stereo with allot of bass.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Ah ha! how do I get into the tail so I can get to the screws? Does it just pop off? Forgive me, I am a new Porsche owner and I just don't want to do further damage to any part of the car.
a.k.a. G-man
it does not pop off. Maybe, if you pull it really really hard.... (that's a joke, don't!)
if you open the deck lid you can have a look from underneath. The tail bolts onto the decklid, you can remove it if you want by unbolting it. Get a digital camera and post pics, that we we can help you better.
Сидеть, ложь, Переворачиваться Last edited by Geronimo '74; 02-08-2011 at 05:13 AM.. |
Fleabit peanut monkey
Suggest removing tail for a better repair. This is from memory.
Get a friend. Drop the AC condenser without disconnecting from system (center hanger and bolts on the hinge bodies). Disconnect engine light connections. Remove shock pins/bolts from hinge while friend holds tail up Place folded over rags under the front most corners of the engine lid to spare paint from damage Remove hinge bolts while each person helps holds the tail up and in place Pull off Investigate for missing hardware. Check the hardware holes in the tail for damage. If oversize repair with epoxy and carefully re-drill for accepting new screws. |
Nesslar, it does sound like I am missing a screw or with no pun intended, I may have a screw loose. I will try to post pics tonight when I get home from work.
a.k.a. G-man
Guys, post #10 in this thread is exactely what you are looking for.
Great inside views of the tail. The original OEM tail thread collective documentation
Page 197 of 495 in this pdf file (available through this website - see new parts catalog) shows the various screws for the 84-86 tail. Part numbers and sizes.
http://www.porsche.com/all/media/pdf/originalparts/usa/911_USA_84_86_KATALOG.pdf Edit - Oops - did not see Geronimo's post |
a.k.a. G-man
No worries Bob, now they have the part numbers too, in case they need to order.
a.k.a. G-man
According to PET http://www.porsche.com/all/media/pdf/originalparts/usa/911_USA_84_86_KATALOG.pdf page 197 says it all. DIY will also work of course
