jm993rs's Avatar
Originally Posted by TRE Cup View Post
buy these from me
I search this model and what is the reference of this piece ??????
Old 02-26-2011, 05:43 AM
Registered speed offender
78SCRSMAN's Avatar
The link is in the very first post near the bottom!
Here it is again:
Originally Posted by 78SCRSMAN View Post
If you keep looking back, you'll never move forward.
http://forums.pelicanparts.com/paint-bodywork-discussion-forum/506621-project-911r-something.html
Old 02-26-2011, 05:51 AM
drb930's Avatar
Subscribed!
Thanks,
Dave
3 Things To Live By - You can't be Too Rich, Too Thin, or have Too Much Horsepower!
Old 06-18-2011, 09:51 PM
great information! however does anyone know where you can get the housings??
Old 07-20-2011, 01:30 PM
RETIRED
Joe Bob's Avatar
TRE, Dave Bozaglu.
2012 ML350 3.0 Turbo Diesel
Old 07-20-2011, 01:35 PM
Where's the best place to get the 911R rear light mounting panels? How about the clear/amber front marker lights?
Old 09-29-2011, 06:20 PM
Keepin' it Simple...
R_Builder's Avatar
Dave at TRE has it all...
-Doug
1968 911R Clone; 11/07-?? (forever the project car )
1978 911SC Midnight Blue Metallic Coupe; 7/05-11/09 (so long impact bumpers)
1973.5 911T Sepia Brown Coupe; 9/98-8/99 (went to a great home)
1973.5 911T Gulf Orange Targa; 5/97-11/02 (went back to Germany)
Old 10-21-2011, 05:27 AM
Senior Member
Great thread!
Old 10-21-2011, 06:42 AM
R_Builder's Avatar
Here is another data point for this job…
Using the tips in this thread, I decided to change the dual bulb tail lights I have for my R project. I used the same paint, but my hardware was older. They are (in theory) NOS from the 70’s and I got them off eBay a few years back from a guy in the UK.
As you can see in the pictures below, they have a “chrome” base that I had to be careful of. My suspicions were verified when I went to work with the acetone… the chrome was painted on from the inside, so in this case the lenses needed to be CLEAR through and through!
Here are a couple pics (with and w/o flash) to show the before and after. The red is quite dark but looks right when you shine light through it. I did 6 very light coats in the end on both to make sure they matched. I stopped at 4 coats on the first one, but was bummed to still see very little paint on the peaks of the fluting inside the lens, even with the “turn over” method. I did the final 2 coats on it VERY light and turned it over right away (as in shoot-shoot-shoot-flip) to make sure the paint wouldn’t run down into the valleys. That did the trick, so on the second one I used the same method on all 6 coats with good results:
Hope that info adds to this a little bit. My thanks to 78SCRSMAN for the original post!
-Doug
Old 11-05-2011, 05:53 AM
Great Info!!
Bill
1987 Marine Blue 911 Carrera Coupe RIP 01/2011
1987 Black 930 RUF Coupe Resurrected, 2488 lbs, EFI Technology, UMS Tuned - Mild & Wild, Current in pieces at paint
Old 02-29-2012, 09:48 AM
Does anybody know where I can purchase four Hella clear side markers lights 001259631 1259. I talked to Truck Styler and they don't handle them any more, also checked on Amazon and e-bay but was unsuccessful
Old 03-20-2013, 04:36 PM
Fabricator
I buy all my lights from rallylights.com they are a big Hella distributor in PA. I make red/red by putting a base from a amber/red behind a red lense. I also use 18watt for brake, turn, and reverse. Use 15watt for tail, I have found that 18 will melt the lense after prolonged use.
Old 03-24-2013, 11:37 AM
