P-Car
woywitka's Avatar
Engine Whine
Hello!
Recently my 1978 SC 3.0 has been making a terrible whining noise. It isn't the typical whine heard when the throttle opens, it is apparant at idle. I'm suspecting perhaps the alternator. It sounds like I have a supercharger.
I have good oil pressure and all, and the engine seems to run very well with no knocking sounds, power problems, or overheating.
Would it be ok from dead cold to start the engine without the fan/alternator belt for just 5 seconds to see if the sound is absent? I know the 911 basically needs that fan or else the engine will literally die; however, if dead cold tomorrow morning (5C or less) can I run it without the belt for a few seconds or will that result in damage?
thanks in advance.
-Tom
1978 911 SC Targa
1975 914 1.8
1980 Mercedes 300 SD
Old 03-21-2013, 11:54 PM
Norm Faustino's Avatar
Maybe try and spin the alt/cooling fan with your hand or wrap a piece of cord around the pulley and pull it to try and duplicate the noise with the motor off first. Just a thought?
78 911 SC "Scratchy"
2004 Mini Cooper S "Pele" (gone but not forgotten)
1979 classic mini clubman-"Coolio"
Old 03-22-2013, 12:00 AM
Member 911 Anonymous
DRACO A5OG's Avatar
+1 remove belts one at a time to eliminate alternator/fan belt being to tight or vevn pulley rubbing against the fan housing. if you have ac, eliminate the compressor.
do not let it run for a long time battery will drain and worse she will over heat.
'85 Carrera Targa
PCA/POC
Old 03-22-2013, 12:24 AM
P-Car
woywitka's Avatar
Thanks guys!
No a/c and air pump was removed by PO, so just one belt.
I will just run it for a few seconds without the belt then.
I should mention I did change the belt back in November before a long trip to California and back. I originally did install it to tight at the fan blades were touching the fan housing, but then I loosened it a bit and all seemed well.
Old 03-22-2013, 11:20 AM
theiceman's Avatar
you should be able to start it and run at idle for quite a while . a few minutes for sure before the temp even begins to move .
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 03-22-2013, 04:45 PM
moneymanager's Avatar
Leave the wife at home?
jhtaylor
santa barbara
74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's.
73 Targa (gone but not forgotten)
Old 03-22-2013, 05:36 PM
P-Car
woywitka's Avatar
lol.
Thanks for the help guys. It is most certainly an issue with the alternator, car sounds great with the belt off, and when I spin the fan/alt by hand there is some crunching sounds. Time to send the alternator off for a rebuild.
-Tom
1978 911 SC Targa
1975 914 1.8
Old 03-24-2013, 11:11 AM
DRACO A5OG's Avatar
it might just need repacking of grease, just use a pin tool, remove plastic cover and pack some bearing grease in there. if it still whines, then send it off, check regulator while you at it.
'85 Carrera Targa
PCA/POC
Old 03-24-2013, 12:44 PM
