Banned
Send a message via AIM to prebordao Send a message via Yahoo to prebordao Send a message via Skype™ to prebordao
Fixing odometer
The odometer (total and trip) on my speedo suffers from a common ailment: sometimes it works, sometimes it don't (more often)...
I happen to have the "guts" of a working speedo from a 70'T. This one still has metal gears unlike my 74' which has plastic ones, I believe.
Is it possible to transplant them into the a 74' speedo ? will it work ? both are mechanical, but...
Old 02-05-2011, 09:15 AM
Location: Behind the redwood curtain, (humboldt county, way north california)
My 74 also has a funky, (inoperative) odometer.
Page 209 in the 101 projects book has a good write up on it. I have just had a few more pressing issues.
Looking forward to seeing how yours comes out.
chris
Old 02-05-2011, 09:32 AM
Kraftwerk's Avatar
I would say you have to take them both apart and compare the two gears. Replacement gears are available. I have done it, but them i twacked the needle and screwed the all works and ended up having to send it in anyway, lost time and money but, oh so much experience..
jt
'83 SC
'96 M3
6 Bicycles
2 Sailboats
Old 02-05-2011, 10:35 AM
North Hollywood Speedo or Palo Alto Speedo. Quality work and fair prices. To keep your Porsche odometer healthy - never ever reset the trip meter when the car is moving.
Old 02-05-2011, 10:52 AM
Insert Tag Line HERE.....
rattlsnak's Avatar
Where can you get replacement parts? NHS and PAS will not sell them outright..
Old 02-14-2011, 09:35 AM
Kraftwerk's Avatar
(HINT: there's a new invention called: GOOGLE!)
Odometer Gears | 72 Croatan Road | Newport News, VA 23606 | 757.593.3478
The gear itself is a cheap-easy fix but I snapped off the "speedo-pointer" when re-assembling the thing and had to send it to North Hollywood who did a great job btw
jt
'83 SC
'96 M3
6 Bicycles
2 Sailboats
Old 02-14-2011, 10:01 AM
pete3799's Avatar
I believe Wayne (Pelican) is now selling those also.
Pete
79 911SC RoW
Old 02-14-2011, 11:07 AM
E Sully's Avatar
Not a hard fix, just be careful and patient removing the needle.
Porsche 911 & Carrera Gauges and Miscellaneous - Page 4
Ed
1973.5 T
Old 02-14-2011, 11:34 AM
Woodyhfd's Avatar
FYI to anyone who's tripometer is not working:
A couple of years ago, I sent my speedometer to North Hollywood Speedometer for a rebuild. My odometer was working fine, but the speedo was not.
After I got it back, everything was working fine except the trip odometer, which worked before. I found that the reset button wasn't releasing all the way, which was preventing the numbers from turning. It loosened up after a bunch of resets, but I always make sure that it has fully released each time I reset.
1987 911 Coupe, Diamond Blue Metallic
2006 Cayman S, Seal Gray
1983 911 Targa, Black: The Dirty 911 (GRM)
Old 02-14-2011, 11:36 AM
Sorry to piggyback. I did the gear fix last summer which worked fine till last week when I noticed my odometer jumped from 177xxx to 277xxx. How the heck do I fix that!?
Old 02-14-2011, 12:15 PM
rattlsnak's Avatar
Not sure how it happened unless something went back together crooked, but if you take it back apart you can "adjust" the mileage to where it should be.
Old 02-14-2011, 06:01 PM
