Dumb Heater Question
Before I rip into the wiring of my 76 S, does the engine have to be running to run the heater blower?
Old 02-13-2011, 05:43 PM
Member 911 Anonymous
DRACO A5OG's Avatar
No, turn the key to on position and lift the lever, the motor will start to run
'85 Carrera Targa
PCA/POC
Old 02-13-2011, 05:48 PM
Well I tried that. Kinda figured thats the way it would work. Wiring I guess.
Thanks for the answer.
Old 02-13-2011, 05:53 PM
DRACO A5OG's Avatar
Check the lever/s, when pulled up it should engage the copper contacts, identified by yellow wires connected to it. Next check the fuse then connector at the motor for voltage.
If all good, then your motor may be shot. Remove and see if it moves freely, it may have binded by rust. Take not it's position before removing.
'85 Carrera Targa
PCA/POC
Old 02-13-2011, 09:38 PM
Well I have determined the motor is shot, it reads open and wont turn with 12 volts hooked directly to it. The wiring diagram I have is poor at best. It does not show the actual routing in the car or the control levers. I was going to start at the levers. Do both levers have to be raised for the switch to work? If so I can read for continuity of the switch from there.
Thanks for the help.
Old 02-14-2011, 05:46 AM
Fleabit peanut monkey
Bob Kontak's Avatar
Only one needs to be up.
Old 02-14-2011, 08:52 AM
RETIRED
Joe Bob's Avatar
This site has wiring diagrams and they are also available on the net.
2012 ML350 3.0 Turbo Diesel
Wink
Should have checked this thread earlier. Just today went to the parts store bought a universal fan relay and wired it in. Drive a purist up the wall but the heat blower will work as advertised when I replace it.
Old 02-14-2011, 07:04 PM
