IAN IAN is offline
Rebuilt Entire Brake System: Rear Right Wheel now locks up first
I recently rebuilt my braking system which included:
1) a new master cylinder
2) All (4) calipers were removed and rebuilt so the the pistons easily slid in and out of the caliper. Used caliper rebuild kits.
3) New pads
4) Bled system which now has a nice firm pedal to it.
The brake lines were replaced a few years prior.
I now notice that when I apply enough pressure braking to lock the brakes that the right rear wheel locks up first.
Anyone have any theories on this and how to address the problem?
Old 02-18-2011, 08:49 AM
IROC's Avatar
I had a front brake locking up prematurely once and it turned out to be a corner balance issue...
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 02-18-2011, 09:22 AM
Max Sluiter
Flieger's Avatar
Did you bed in the pads?
Old 02-18-2011, 09:32 AM
Senior Advisor
James Brown's Avatar
Sounds like the big two in brakes, bedding in and corner ballance. Best checked with scales and try a bunch of high speed stops not locking up the brakes but being pritty agressive. or drive in LA traffic. This is normal.
08 Cayenne Turbo
Old 02-18-2011, 09:38 AM
IAN IAN is offline
I did "bed" the pads by making many aggressive stops.
Old 02-18-2011, 09:51 AM
ghamilton's Avatar
Ian:
Here is the official way to bed in the brakes, I never actually knew all the details, esp about not coming to a complete stop.
StopTech : Balanced Brake Upgrades
G. Hamilton
'82 SC Guards Red-2nd time owned-Now sold
"Bumerang"
'70 TR6
N of Boston
Old 02-18-2011, 09:55 AM
i just did a full caliper up-grade
i went through all the bedding etc etc motions and still had a slight front right side pull.. for awhile it drove me nuts till i said "screw it"
never the less, little by little and 500 street miles later the pull is almost gone
i found this routine very unusual
otherwise good luck on going through the after rebuild motions again
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 02-18-2011, 11:17 AM
Max Sluiter
Flieger's Avatar
Then I would go with option #2- corner balance.
Have you checked the tire pressures?
Old 02-18-2011, 01:32 PM
