Jupiter 911
I know, wrong forum, help!
My wife's 2002 Boxster check engine light came on, code P1130. I plan to take out the after market filter, clean the MAF and clean the throttle valve and check for vac. leaks. My question is can someone post a site on throttle valve cleaning, maybe from Waynes book? Sorry for the post but no one on the Boxster side. Thanks lenny!!
Lenny-1987 3.2 Targa Guards Red/SW Chip Fabspeed Exhaust/Cat bypass MSDS Inc. intake/Clewetts Euro pistons and cylinders. 2002 Boxster Artic Silver/Wifes ride. |
I don't have link but I routinely clean the throttle valves on our cars. I use simple carb cleaner and spray it inside the opening around the butterfly. You probably will see black/brownish residue. Work the throttle by hand so that it moves freely.
The MAF sensor needs a special cleaner so go to the parts store and get some before starting. DO NOT use carb cleaner on a MAF. http://www.pelicanparts.com/techarticles/Boxster_Tech/28-FUEL-Throttle_Body_Cleaning_-_Boots/28-FUEL-Throttle_Body_Cleaning_-_Boots.htm EDIT-found a link that works ![]() I hope this helps some.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne Last edited by Oh Haha; 02-26-2011 at 05:45 AM.. |
Jupiter 911
Thanks Wayne this is what I needed, by the way I have a Max Scan GS500 do you know how to reset the check engine light with this tool? I went over and over the manual several times.
Sorry, I still haven't bought a scan tool.(I know I know.)
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
Bklyn, you may wish to check out PedrosBoard.com. It used to be PorschePetesBoxsterBoard, but sadly, Pete passed on. Pedro took up the board. Lots of good stuff for Boxsters here, and he is in FL and a good guy, not far from you. Active group. Glenn
Section 4.2 in the owner's manual indicates that you should be able to select "erase codes" and then confirm the command. I used your model number for doing the search and then used the PDF to read the manual section.
You gotta love technology. if all else fails, the Autozone crew can erase codes for you.
Jupiter 911
Hey Wayne, this worked!!! Thanks guys
Glad I could help.
I've already put my request in with the financial controller(wifey) for a scan tool for my b-day.
Jupiter 911
I believe it was around $69.00 with cables and a soft case. Seems to work well for that price.
Member 911 Anonymous
Just disconnect the battery and reconnect after 10-20 seconds, that should reset it.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
