Jupiter 911
bklyn's Avatar
I know, wrong forum, help!
My wife's 2002 Boxster check engine light came on, code P1130. I plan to take out the after market filter, clean the MAF and clean the throttle valve and check for vac. leaks. My question is can someone post a site on throttle valve cleaning, maybe from Waynes book? Sorry for the post but no one on the Boxster side. Thanks lenny!!
Lenny-1987 3.2 Targa Guards Red/SW Chip
Fabspeed Exhaust/Cat bypass
MSDS Inc. intake/Clewetts
Euro pistons and cylinders.
2002 Boxster Artic Silver/Wifes ride.
Old 02-26-2011, 04:13 AM
Oh Haha's Avatar
I don't have link but I routinely clean the throttle valves on our cars. I use simple carb cleaner and spray it inside the opening around the butterfly. You probably will see black/brownish residue. Work the throttle by hand so that it moves freely.
The MAF sensor needs a special cleaner so go to the parts store and get some before starting. DO NOT use carb cleaner on a MAF.
http://www.pelicanparts.com/techarticles/Boxster_Tech/28-FUEL-Throttle_Body_Cleaning_-_Boots/28-FUEL-Throttle_Body_Cleaning_-_Boots.htm
EDIT-found a link that works
I hope this helps some.
Pacific Blue
Wayne
Old 02-26-2011, 04:38 AM
Jupiter 911
bklyn's Avatar
Thanks Wayne this is what I needed, by the way I have a Max Scan GS500 do you know how to reset the check engine light with this tool? I went over and over the manual several times.
Old 02-26-2011, 04:58 AM
Oh Haha's Avatar
Sorry, I still haven't bought a scan tool.(I know I know.)
Pacific Blue
Wayne
Old 02-26-2011, 05:02 AM
p911dad's Avatar
Bklyn, you may wish to check out PedrosBoard.com. It used to be PorschePetesBoxsterBoard, but sadly, Pete passed on. Pedro took up the board. Lots of good stuff for Boxsters here, and he is in FL and a good guy, not far from you. Active group. Glenn
Old 02-26-2011, 05:09 AM
Oh Haha's Avatar
Section 4.2 in the owner's manual indicates that you should be able to select "erase codes" and then confirm the command. I used your model number for doing the search and then used the PDF to read the manual section.
You gotta love technology.
if all else fails, the Autozone crew can erase codes for you.
Pacific Blue
Wayne
Old 02-26-2011, 05:13 AM
Jupiter 911
bklyn's Avatar
Hey Wayne, this worked!!! Thanks guys
Old 02-26-2011, 05:31 AM
Oh Haha's Avatar
Glad I could help.
I've already put my request in with the financial controller(wifey) for a scan tool for my b-day.
Pacific Blue
Wayne
Old 02-26-2011, 08:20 AM
Jupiter 911
bklyn's Avatar
I believe it was around $69.00 with cables and a soft case. Seems to work well for that price.
Old 02-26-2011, 10:43 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Just disconnect the battery and reconnect after 10-20 seconds, that should reset it.
'85 Carrera Targa
PCA/POC
Old 02-26-2011, 01:23 PM
