Damaged fan
I found that the fan on my '77 has a piece missing from one fan blade. Is it OK to use this fan or do I need to get another one?
1977 911 2.7 Stock restoration in progress |
abit off center
Be a good time to upgrade to the 11 blade fan I guess. But run it until you find one.
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
But I'm a stock guy and live in cold Sweden.
abit off center
In that case I would just clean up the edges and put it back in. I don't think balance will be an issue. do you have problems with the engine not warming up then? If so something I wish I could run here would be a power pulley which is smaller and slows the fan down and gives you more hp I guess.
Member 911 Anonymous
Even my 11 blade has the same exact chip. Don't worry about it, just clean and replace.
It is the housing surround that I would worry more about. I am just wondering how the heck does that happen?
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Make Bruins Great Again
In the lower 48 everyone wants to replace their 5 blade. You should be able to find one for a song. Shipping will cost more than the fan. Keep the old one as a backup should you ever crack the new one.
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
