dar636
Windshield Wiper performance
Hi-
Is the reason that windshield wipers are altered to park on the passenger side to keep them stowed flat against the glass so the drivers side blade actually contacts the glass when it swipes? Or for something else?
My drivers side has never worked well due to the "set" it takes when parked. I have tried different brands of rubber, not much help. Suggestions?
Old 03-01-2011, 06:09 PM
Band.
I think the windshield wiper flip is just to provide less junk in your field of vision.
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 03-01-2011, 06:12 PM
Wash. State
nesslar's Avatar
You might get a better swipe with the reversal, though; sounds very reasonable. Driver's side wiper would be sitting flat against the glass when parked.
Old 03-01-2011, 06:29 PM
Member 911 Anonymous
DRACO A5OG's Avatar
I've used PIAA's silicons for 4 years, they seem to work well.
'85 Carrera Targa
PCA/POC
Old 03-01-2011, 06:34 PM
Northern Motorhead
wildcat077's Avatar
I switched mine to have a better vision from the driver's seat ...
Don't drive my car much in the rain,it's just too much of a PITA to keep
a black car clean afterwards !
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 03-01-2011, 07:16 PM
Robby Robinson's Avatar
I've read about this switch before as well. Look at some pictures of British 911s sometime. The wipers are parked in front of the driver, so Porsche reversed them to again be in front of the steering wheel. Go figure.
88 Carrera cpe
mostly stock
Old 03-02-2011, 12:15 PM
Richard Burns's Avatar
When you don't use the car in the rain the wiper blade in front of the driver gets what they call a memory and retains the bend. When you need to use the wipers you have a spot right at eye level that does not get wiped. Many people choose to reverse thier wipers to stop this from happening.
An easy rectification is to simply change the blades from one wiper arm to the other it takes all of 2 minutes the first time and is quicker after that.
Life is not a journey to the grave with a pretty and well preserved body but to skid in sideways, used and worn out saying " What a trip!
Old 03-02-2011, 02:09 PM
N-Gruppe doesn't exist
teenerted1's Avatar
Location: *%@#ing GPS, where am I? Oh wait I see the Space Needle.
Send a message via AIM to teenerted1
anyone try the new skinny all in one blades (blade refill and holder), like the new rain-x ones; DD uses the ones by bosch, but cant find them smaller than 17" here. just saw some others in 14" (regular 13" are hard to find sometimes) so those are almost short enough. i hear you can cut some to size and just stick the ends back on.
scooter reversed his and only uses one long one and it worked for him
Ted
'70 911T 3.0L "SKIPPY" R-Gruppe #477
'73 914 2.0L SOLD bye bye "lil SMOKEY"
"Silence is Golden, but duct tape is SILVER.”
other flat fours:'77 VWBus 2.0L & 2002 ImprezaTS 2.5L
Old 03-02-2011, 02:17 PM
Formerly known as Syzygy
Canada Kev's Avatar
I think you can cut or trim down the ends of the blades with a sharp knife.
Kevin
Old 03-02-2011, 03:36 PM
Diss Member
Quicksilver's Avatar
I put Silblade silicone blades on 5 or 6 years ago and have never had to replace them again. The rubber ones break down so fast and after a summer of ozoning to death they are dead by the time we need them again.
Cheapest $22 dollars I ever put into the wipers.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 03-02-2011, 04:09 PM
2Utes's Avatar
i reversed mine and the driver's side does wipe better in your field of vision. it misses the lower corner at it stock rest position. living in Oregon, i am happier when the wipers are needed.
i trimmed a newer blade shorter and tried it on the driver's side. it worked about the same as the stock blades. it seemed to me that the effective spring set of the blade was stiffer once it was shortened.
i have kept the reversed position because it is the best solution for my use and local conditions.
Jeff
'82SC Pacific Blue
'02 C4S Silver (Gone but fondly remembered)
'11 GTS Amethyst
Old 03-02-2011, 04:16 PM
dshepp806's Avatar
I've often wondered about this area of unwiped surface that shows right in the drivers' view.
New blades seem to remedy it, but only for a short while. It looks, to me, that one would change the actual ARMS (not just the blades) to addres this......no reversal needed...
NO?
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 03-02-2011, 06:13 PM
dar636
Thanks for all the replies. As I understand it I am sitting on the wrong side of the car.
I'll try out one of the alternate blade refills, and maybe shortening the blade a bit. They are 13" refills from Bosch but they didnt last too long. Just another 911 quirk.
I still plan on driving it frequently, Seattles weather isn't the best but it doesnt leak and the dirt washes off. Just not in front of my face. With the wipers.
Old 03-02-2011, 07:20 PM
