2nd that........where did you get the brace?
Thankx, I did.
Probably more bling than function. Welded on the brackets when the car was stripped, then added the bars once it was together.
1975 914 2.0 1970 911 T |
Start it in the evening with the engine compartment open and look for little blue electrical discharges around the MSD connections especially at the coil connection.
1981 911sc Targa Rosewood (sold to Rob) 1983 911sc sunroof coupe Guards red 1986 930 (Sold, but not forgotten) |
your carbs may be dirty if you're using routine 10 micron fuel filters
a Racor with 2 micron filters is trick
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Thread Tools | |
Rate This Thread | |
