Banned
Send a message via AIM to prebordao Send a message via Yahoo to prebordao Send a message via Skype™ to prebordao
What color is the inside of your tailpipe ?
I know this is no replacement for a proper tune up procedure, but after a good spirited drive, what should look like the tailpipe of a properly adjusted car (without cat) ?
Old 03-04-2011, 02:09 AM
I think with no-lead fuel these days it will always be either black or just the pipe color. The gray color that you looked for in the old days was lead deposited on the exhaust pipe, or so I was told.
Art
'75 911 US Carrera #390
'74 MGB, AH 3000 BN7 V8,
'65 Mustang Fastback, 66 bronco U13
Old 03-04-2011, 05:30 AM
Designer King
Paulporsche's Avatar
Mine is a dark gray; not quite black. And no soot on the u/s of the bumper.
CIS, no cat, no O2, Sunoco (now Petrocan) 94
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 03-04-2011, 05:38 AM
Banned
I'm getting a light gray.
Old 03-04-2011, 05:40 AM
Banned
just to add, the last couple of tanks were of 98RON
Old 03-04-2011, 06:37 AM
Unleaded fuel tends to lack any tan coloration, leaving a gray residue of varying darkness. If you are using leaded fuel, you will see a gray/tan coloration. As long as the pipe is not sooty, your description sounds okay. A larger concern would be an overly lean mixture which you may wish to check by looking at the plugs themselves or testing with a gas analyzer.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 03-04-2011, 10:21 AM
pink
206 637 4071
Old 03-04-2011, 12:06 PM
Originally Posted by john walker's workshop View Post
pink
That's what I was thinking, you said it first, tho. ha
Old 03-04-2011, 01:18 PM
Goldfinger
Mattcamp's Avatar
pink
I was wondering who would be the first to answer such a personal question. Nice job JW.
1984-Carrera (pewter metallic)
Old 03-04-2011, 01:25 PM
If I may offer,....
Tailpipe colors reflect gasoline formulations, thats all. Depending on what fuel we use, I can see anything from all shades of grey, dark brown, light tan, and med brown.
It doesn't reflect mixture strength and should never be used to judge whether an engine is rich or lean. Thats why we either learn how to properly read spark plugs, or install a wide-band AFR instrument.
Those folks who engage in using tailpipe colors to determine air-fuel ratios may be purchasing some expensive engine parts in the future.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 03-04-2011, 05:53 PM
