Banned
What color is the inside of your tailpipe ?
I know this is no replacement for a proper tune up procedure, but after a good spirited drive, what should look like the tailpipe of a properly adjusted car (without cat) ?
I think with no-lead fuel these days it will always be either black or just the pipe color. The gray color that you looked for in the old days was lead deposited on the exhaust pipe, or so I was told.
Art '75 911 US Carrera #390 '74 MGB, AH 3000 BN7 V8, '65 Mustang Fastback, 66 bronco U13 |
Designer King
Mine is a dark gray; not quite black. And no soot on the u/s of the bumper.
CIS, no cat, no O2, Sunoco (now Petrocan) 94
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone Last edited by Paulporsche; 03-04-2011 at 05:50 AM.. |
Banned
I'm getting a light gray.
Banned
just to add, the last couple of tanks were of 98RON
Unleaded fuel tends to lack any tan coloration, leaving a gray residue of varying darkness. If you are using leaded fuel, you will see a gray/tan coloration. As long as the pipe is not sooty, your description sounds okay. A larger concern would be an overly lean mixture which you may wish to check by looking at the plugs themselves or testing with a gas analyzer.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
pink
Goldfinger
I was wondering who would be the first to answer such a personal question. Nice job JW.
1984-Carrera (pewter metallic) |
Tailpipe colors reflect gasoline formulations, thats all. Depending on what fuel we use, I can see anything from all shades of grey, dark brown, light tan, and med brown. It doesn't reflect mixture strength and should never be used to judge whether an engine is rich or lean. Thats why we either learn how to properly read spark plugs, or install a wide-band AFR instrument. ![]() Those folks who engage in using tailpipe colors to determine air-fuel ratios may be purchasing some expensive engine parts in the future.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
