83 911 Production Cab #10
Timming Chain Cover Removed * While I'm in there?
So, I'll be changing the gaskets, O'rings for Banjo Bolt receiver (actually the left cover came out too easily).
Anything else? What is the "plug" for, beside the Banjo Bold hole on the covers? ![]()
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger Last edited by JJ 911SC; 03-18-2011 at 05:49 PM.. |
Oops... Post too fast
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Somatic Negative Optimist
Not sure what you mean But make sure to install new small O-rings on the shaft for the banjo fitting. They seal the hole in the covers. Old seals leak!
Yeah, the 2 seals are comming. Actualy the right one was leaking. I meant, is there anything else I should check & what is that plug on the cover (4th photo)? JJ
#4 picture, plug is the support for the pin that the tensioner sits on. It is only pressed into place and then sealed from leaking on the pin side you cant see.
Bruce |
abit off center
You could add the internal tensioner stops at this time. Its a good safety items should it ever fail.
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Home of the Whopper
Verify / adjust cam timing.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller |
Bruce
Thanks, I notice there is a black "cement" in the inside to seal it. Craig Never heard of this... But then again. I'll use my friend the "search". BK911 Haven't done a Valve adjustment yet... So maybe next time. Thanks JJ
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger Last edited by JJ 911SC; 03-05-2011 at 02:52 PM.. |
The right cam gear looks completely worn out in the picture.
Bruce |
Home of the Whopper
JJ: While you are that close, I personally would not button it up without adjusting intake valves 1 & 4 and verifying cam timing. You are sooo close already! In fact, I would adjust all the valves. Cant hurt.
Holy poop, I didnt notice that!! Good catch,
could be over 100k miles?
I'd probably spend a couple of hundred $ in there to buff it up if i was going to keep it nice pics
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
That is why I posted... I will take some close-up pics. Any measurement I should do or you can just eyeball it? There goes my April 1st date... BK911 So you are saying to do the Valve adjustment without seal the covers, not a problem since it look like I'm deeper than O'ring and seal ![]() ![]()
i'd advance the cams as much as possible
....... but that's just me
OK, let me have it... At least they seem even.
Right: CAM Sprocket: ~5mm Lifter Sprocket: ~6mm ![]() Left: CAM Sprocket: ~5mm Lifter Sprocket: ~6mm
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger Last edited by JJ 911SC; 03-18-2011 at 05:52 PM.. |
6th and last owner so its a keeper ![]() ![]()
I'm no expert
Pelican# 901.105.546.02.M260
Senior Advisor
They look fine, i think it was the picture lighting that everyone thought was worn out chain sprockets. However, it looks like the lower chain on the left side is cracked through.
J/K, carry on. Cam timing advancement can help with low end or high end depending where you set them (+-) but only a degree ether way, be carful.
08 Cayenne Turbo |
I wont be playing with advancement... I don't see what you are referring to about lower chain on the left side is cracked through it even sound worse then worn Sprocket
Senior Advisor
It's just a joke,
![]() ![]() ![]() ![]() feel the love?
08 Cayenne Turbo |
Actually... I started to think that you were talking about the chain breaking trough the light.I can feel it (love) but I made another trip to the garage ![]() ![]() wont bother to post the photo
