Electrical lights problem
Hi, i have a 911 1986. I have intermittent problem with my marker light, flasher light rear and front, right and left. Suddenly, flasher dont run, after one day, it run again. I have check the bulb and replace it. Both side of the car. This is the same for marker light. One day, I test the current into the socket (marker light), no current found. A day later, the marker light is ok. Do you have a way to check ?
Roger.
Banned but not out, yet..
Try switching your flasher relay with another and see if your relay is at fault
An air cooled refrigerator. ‘Mein Teil’ |
Sounds like the Ground Gremlins are at it again!
1982 911SC Wine Red Metallic OMG I love this car! |
+ 1 for bad earth/ground, check those first, especially on all 4 lights, one side at a time
spin the fuses in the holds to clean them
Hi, do you know where is the ground 414 ? I can`t find it. I cleaned the ground 106. Theses two grounds are linked with the rear lights. The 106 was in very bad shape with oxidation.
Roger |
Member 911 Anonymous
414? where did you see this diagram listed?
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Okay, the best thing to do is carefully remove the light assemblies and look behind them where the wires are connected for corrosion or loose connectors. If you live in a heavy wet area the connections can get pretty corroded. My car came from Tennessee, the connectors were pretty corroded and not allow full continuity. Yes, the ground wires are in the back of the assemblies.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 05-27-2016 at 12:09 PM.. |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Lights.
![]() ^^^^^ Front end electrical from the factory manual. ![]() ^^^^^ Grounding points. Check your fuses Good luck, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Thank you
I will check it. Roger |
Even though the fuse may look good, grab with your finger tips and rotate/spin them, if loose versus a known good fuse, replace it, this will also lap them to the fuse holder if there is some corrosion on them not allowing a full contact.
I would also gently pull on the wires going in and out of the fuse holders, sometimes they get loose.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 05-28-2016 at 07:41 AM.. |
Hi, do you know where i can find retrofit taillight for my car ?
Roger |
