Tom '74 911's Avatar
Relocating DME ECU Computer - alternative locations?
Hi -
I'm doing a 3.6L conversion and am looking for an alternative location (other then under the driver's seat) to mount the 964 DME ECU Computer in my '74 911. My seats are lowered - I chopped out the OEM mount rails and welded in new cross bars - so there's not enough room under them anymore. I've thought about the floor just behind the driver's seat, the rear seat well behind the driver's seat and the firewall above the rear seat. I'd love to hear about some alternative locations and see photos if possible of what others have done.
Thanks,
Tom
'74 911 Red Sunroof Coupe, 3.6L, etc...
'76 912 Yellow SPEC 911/911CUP
Old 03-12-2011, 10:23 AM
rsscotty's Avatar
I have seen 964 Cup cars with the DME installed on the vertical panel behind the drivers seat. This is the section between the bottom of the rear seat and the main floor.
Old 03-12-2011, 12:54 PM
Diss Member
Quicksilver's Avatar
The seat in my 87 is lowered so the rear portion is below the seat rails so the DME wouldn't fit. I moved it so it is in front of the DME relay and the altitude compensator. The plug is on the left side toward the door. Didn't have to change the harness at all. It pokes out a bit in front of the seat but you can't get your foot on it to step on it.
Loosen it up and push it over there and see if you like the location.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 03-12-2011, 01:04 PM
RETIRED
Joe Bob's Avatar
Big issue is slack in the harness.......or lack thereof.
2012 ML350 3.0 Turbo Diesel
Old 03-12-2011, 01:22 PM
H-viken's Avatar
Originally Posted by rsscotty View Post
i have seen 964 cup cars with the dme installed on the vertical panel behind the drivers seat. This is the section between the bottom of the rear seat and the main floor.
+1
SEARCHING FOR ENGINE 6208326 (last seen in car with VIN 9111101452)
911E Coupe -70
Carrera 3,2 -84 Sold
Old 03-12-2011, 01:24 PM
This is one of the panels I was thinking of. Where does the harness typically pass through the firewall? At the top near the rear cross member or down lower? Looking at the harness I have, it looks like the grommet is towards the engine side - which might indicate that it passed through the firewall higher, rather than lower and then ran under the carpet down the inside? It looks like I'll need to cut a pretty big hole to pass the connector through. I haven't measured the grommet yet, but it looks big!
Thanks for the ideas,
Tom
Old 03-12-2011, 02:20 PM
Bill Verburg's Avatar
Here's where mine goes through, drivers side. This is the same spot where the 964/993 go though
Cups mount them either on a vertical panel behing the seat or horizontally behind the seat.
vertical, mostly used w/o air jacks
horizontal, mostly used w/ air jacks
Bill Verburg
Old 03-12-2011, 02:59 PM
Bill -
Thanks for the great info & pics. - really helpful!
Tom
Old 03-12-2011, 03:18 PM
rsscotty's Avatar
Here are a couple of pictures that may be of some help.
The aluminum plate was used to mount the DME on the race cars.
Old 03-12-2011, 04:56 PM
rudya's Avatar
Originally Posted by Tom '74 911 View Post
Hi -
Thanks,
Tom
I deleted the rear seat because it's all rusted out and install it in that area.
Old 03-13-2011, 01:25 AM
