I've inspected about 1000 miles of weld using everything available. I can honestely say I've never met a pinhole I liked. Visual inspection gives (at best) an indication of weld quality. If it looks like hell you can bet it would look even worse
using X-ray or ultrasonic. Anyone can educate ones self to visual flaws. If you're not familar with visual welding flaws, find someone that is. Generally, if it looks like S***, it is. It's your ass.
JPIII Early Boxster |
Administrator
Conversely, some welds look great -- but aren't.
I've been driving on welded wheels for almost ten years now -- no issues. Mine don't have welded seams along any pressurized areas, but by the look of them the welds wouldn't have a problem with that. I personally would be a little anxious relying on silicone to maintain air pressure, but most 3-piece wheels do that without any problems.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
When we test welders to an AWS-1.1 standard pin holes would disqualify any welder for our shop. Also, pretty welds to some are awful welds to others who know what they are looking at. Saying that pin holes are acceptable is simply anything but accurate.
Lindy |
SAIGON 68
pictures required. there are some really good welders on the pelican forum. it doesn't take dye-check or an x-ray to spot a garbage weld. if the tire changer guy threw up on your wheels, they might be suspect.
Sherwood |
If you handed 95% (or more) of the people on this board a weld X-ray they wouldn't know a defect if they saw it......unless there were holes big enough to throw a cat thru. You have a better idea than a visual inspection? The Navy, Coast Guard, & ABS accept visual inspection of structural welds *IF* the welder is certified. If your welder has no paper.....well, it's your ass.
How many on this board would know how to confirm the traction control system is working correctly on a new car? Many perhaps, but the point is to seek the advice of more knowledgeable persons when there's an experience or information gap. Sherwood |
If it flows, it goes. If its smooth, it moves. Any questions? 96 993 C2 (Current) 87 911 Factory Turbo-Look Cab (Sold) 85 911 Factory Turbo-Look Targa (Gone) |
Under the radar
What about re-heat-treating the wheels after they are welded? Is this commonly done? Is this required or desired? Does anyone do x-Ray inspections?
Thread Tools | |
Rate This Thread | |
