Is my compressor usable/sellable/junkable?
Pulled this off my engine today along with the other A/C components that were disconnected/destroyed.
I tried Googling the labels I found on it, but no results.
Is this thing worth anything, will it even still work (is it R-12?), is it worth selling, or should I just junk it? I have no idea if it works. It had a belt on it and it spins!
DD summer/winter: 2000 Boxster S
DD spring/fall: 914-6 w/ 3.0L SC Dual Webers (For Sale)
http://imgur.com/a/k0Wtl - My 914-6 Build/Project Story
Old 03-17-2011, 07:20 PM
Scott R's Avatar
That's a Sanden 508, nice compressor, R134 btw. Are there any other pieces of the system that you can post? Forgot to add that it's probably very usable, give the clutch 12V and see if it works, it probably does those are good little units.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 03-17-2011, 07:36 PM
Oooh, if its R134 I take back everything I said, I will keep it. I was under the impression from the PO that it was R-12.
Had to throw the condensor out though, it was banged up and had its lines crimped.
Old 03-17-2011, 07:48 PM
Scott R's Avatar
It can use either r12 or 134, I just figured it was 134. But who knows what you PO did...
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 03-17-2011, 08:06 PM
Fleabit peanut monkey
Bob Kontak's Avatar
For what it's worth, you can still buy R-12 on Ebay as long as you send/fax a form to the seller stating you will resell the R12.
R-12 Refrigerant 14 oz can Case of 12 - eBay (item 260753819177 end time Apr-16-11 09:38:43 PDT)
I think there are pretty decent R12 replica refrigerants out there so may not even be a point of interest any more.
Oh, you want more factoids? - The atomic half life of R12 (I think the freon) is close to 100 years. If you find some in an old garage it may real tired.
Old 03-17-2011, 08:19 PM
When you say it can use both, is it interchangeable...or do you need the conversion kit?
Is there a way to tell which one it's currently setup for?
Old 03-17-2011, 08:23 PM
Bob Kontak's Avatar
Yes - you need the conversion kit. I run R12 in my Sanden. To switch to R 134 I have to go through the purging process and get the R134 valves.
Old 03-17-2011, 08:30 PM
Bob Kontak's Avatar
I suspect your's is R12 but I can post pics of my unit in the morning. Also see this link from EBay showing the fitting sizes. EDIT - The R12 valve is the one on the left in the link below.
R134a to R12 & R-12 to R-134a Brass Fitting Adapter Set - eBay (item 350446696356 end time Mar-18-11 09:25:25 PDT)
Old 03-17-2011, 08:32 PM
Ah, so the fitting sizes will dictate if it takes R12 or R134. I will check this evening.
Little disappointed, I was hoping for it to be R134. Those conversion kits such as the one on PP are expensive!
Old 03-18-2011, 11:43 AM
Bob Kontak's Avatar
Here is the side of my compressor with the R12 set.
The ebay adapter set is $4.95. Do some searching. There is more to it than just switching adapters.
up.
Old 03-18-2011, 11:52 AM
Ken911's Avatar
Make sure you change the oil though. r-12 uses mineral oil and r-134 uses ester oil.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
2019 Silverado 6.2L
Old 03-18-2011, 11:59 AM
