MRM MRM is offline
Post 3.2 to 3.4 or 3.5 conversion?
Bruce Anderson writes favorably about getting converting the 3.2 Carrera engine to 3.4 or 3.5 liters. He writes that the 3.4 conversion is truly "bolt on" and can add something like 30 HP, particularly with the euro engine.
I have a eurospec Carrera and have been thinking about this conversion for some time. Does anyone have any more information or opinions on it? I have seen few owners do the conversion, but it sounds like a great idea. Is there a down side that I am not aware of? How much would it cost?
Thanks again, Mike
Old 07-12-2001, 09:55 AM
RLJ RLJ is offline
Senior Registered User
Thumbs up
The way I understand it, all you do is buy new or have your cylinders bored and sleaved to 98mm and buy new pistons and you have 3.4
I'm running sleaved cylinders and 98mm J-E pistons and they work just fine.
Randy Jones
1971 911
Old 07-12-2001, 10:09 AM
Bill Verburg's Avatar
Post
The down side is cost. The appropriate Mahle piston and cylinder set sell for >$3000
Old 07-12-2001, 02:32 PM
RLJ RLJ is offline
Post
Simple don't buy Mahle!
J-E pistons about $1000 with rings and wrist pins.
Bore and sleave cyls. About $1200
Randy Jones
1971 911
Old 07-12-2001, 02:46 PM
Mike the mechanic's Avatar
Post
Motormeister has the 98 mm p/c's for $900, at a variety of compression ratios. Why the big difference in price? They also have cams for $300-350. Are they of poor quality?
Mike
86 Carrera t
Old 07-12-2001, 05:58 PM
Post
Are they just the pistons? Used? Mahle? The going rate for Mahle 98mm pistons with correct wristpins for a 3.2 to 3.4(or a 3.0 to 3.2) conversion from any reputable vendor is as quoted.
Old 07-12-2001, 06:06 PM
Post
They are new sets, but don't specify mahle. I think I will give them a call, just to ease my curiousity. www.motormeister.com
Mike
86 Carrera t
[This message has been edited by Mike the mechanic (edited 07-12-2001).]
Old 07-12-2001, 06:18 PM
Stay away from my Member
campbellcj's Avatar
Post
The motormeister pistons sets for ~$899 are pistons only. They are custom built forged alloy pistons - I am not sure if they are built by JE or someone else though. Kinda curious myself.
Chris C.
Old 07-12-2001, 06:37 PM
Post
Some will tell you, you have to convert to a twin plug ignition when going to >3.2L or else run a lower compression which offsets some of the desired power gain.
[This message has been edited by movin (edited 07-12-2001).]
Old 07-12-2001, 07:46 PM
RLJ RLJ is offline
Thumbs down
There is one thing that you have to remember when you are adding parts to the Porsche. Those parts should be the same quality or better that what is there. The second thing to rememeber is "There is no free lunch" somewhere you will pay for it. If you cherry pick and get the cheapest it's gona' bite you in the ass, been there done that, trust me. If you are going to own a Porache then step up and do it correctly, don't get me wrong about shopping for a price SOS pads are SOS pads buy them at the mini-mart for $3.79 or Walmart for $1.78 if you are getting the same exact thing then price shop but don't get cheap when it comes to things like reground cams, forged pistons, major motor hard parts. Find out what the going rate is and then really really look at the ones that are cheaper before you spend your cash.
Randy Jones
1971 911
Old 07-12-2001, 09:20 PM
