drola's Avatar
LSD or no LSD ???
my recently aquired 87 coupe came with the factory lsd option. my tranny was rebuilt once by a reputable shop. i also have an invoice from a "less" reputable shop where they changed out the diff and slave cylinder. part cost for the diff (rebuilt) was $1000, slave $49, and $450 labor.
is there a way that i can verify if they used an actual lsd diff? without tearing the tranny apart?
IG @Drola964
1973 BMW 2002
1990 964 C2
2007 GT3
2014 Ram 2500 Cummins
Old 03-26-2011, 09:08 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Jack up the rear of the car and get both wheels in the air. With the transmission in neutral, turn one wheel. The other wheel should turn in the same direction. If the other wheel spins in the opposite direction, you have an open diff (or the LSD is completely worn)
Kevin L
'86 Carrera "Larry"
Old 03-26-2011, 10:14 AM
drola's Avatar
when i spin the driver's side wheel, the other kinda wants to go in the same direction but doesn't actually spin.
when i spin the passanger side, the other spins in reverse.
IG @Drola964
1973 BMW 2002
1990 964 C2
2007 GT3
Old 03-26-2011, 11:18 AM
Then "no, you don't have an LSD".
'77 S with '78 930 power and a few other things.
Old 03-26-2011, 12:41 PM
RETIRED
Joe Bob's Avatar
Sounds like you have a loose part in someone else's ride.
I rebuilt my 915 with help from friends. When I took the box to a reputable shop one of the wrenches commented that I shouldn't leave it sitting around as it would disappear very quickly.
Wasn't funny, made me paranoid and put me on my guard. LSDs are a rare and valuable option. I didn't let that puppy out of my sight.
Sounds like you need to call Cousin Guido and make a housecall.
2012 ML350 3.0 Turbo Diesel
Old 03-26-2011, 01:25 PM
gearhead
Be sure you spin the wheel with a fair bit of force when testing it. The ZF LSD used in your gearbox has a pretty low preload and is only 2 plates. A good hard jerk on the wheel (think Price is Right finale wheel spin) will make the LSD lock up a little bit if it's present. Just casually spinning the wheel by hand on that diff won't work in the same way that it would on a 915 or 930 LSD.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 03-26-2011, 04:17 PM
ivangene's Avatar
do a "burn out" on loose surface....if you spin one wheel, take pistol to shop that did the "rebuild"
Ed M
86' Coupe
Old 03-26-2011, 04:26 PM
Why do I hear the Moody Blues singing in the background?
Don Newton
“People sleep peaceably in their beds at night,” George Orwell wrote, “only because rough men stand ready to do violence on their behalf.”
"I gave up visiting my psychoanalyst because he was meddling too much in my private life." Tennessee Williams
Old 03-26-2011, 04:37 PM
drola's Avatar
i have the driver's side shaft out right now for c.v. boot and bearing replacement. when i get it back together i will try turning it with some force and see what happens. and i can't resist a good reason to do a burnout.
that shop did the diff swap back in 2004. the girl who owned the car before me (she owned it for 18 years) would never have known the difference anyway. so now the question is: did they change it out knowing that they were putting a non-lsd and keeping the original or did they not even pay any attention to the fact that it did have lsd and just swap it out for whatever they had on the shelf?
anyway, she got screwed and in turn i got screwed. hard to go back to them after 7 years and complain though.
this is a perfect example of why i think people who don't know these cars and how to work on them should stick to hondas or toyotas. ok maybe even bmw's (they are great cars).
but leave the p-cars to those of us who love them!
other p-car owners often tell me "if you need a good mechanic i know just the guy." i just laugh. the thought of someone else touching my baby - not a chance!
IG @Drola964
1973 BMW 2002
1990 964 C2
2007 GT3
Old 03-26-2011, 09:22 PM
Doing a burnout isn't a conclusive method of determining if you have a LSD.
With a non=lsd differential, If for some strange reason, both tires have the same coefficient of friction, both tires will spin and leave rubber
___________________________________________
2001 Boxster S, Orient Red Current Vehicle,
1973.5 911 full factory "S" trim with a 3.2 engine **Sold**,2002 996 **Sold**,1975 911S **Sold**,
1971 911T **Sold**, 1968 912 **Sold**
Old 03-27-2011, 06:35 AM
Mitch Leland's Avatar
I have a low mileage car w/ the LSD option, but some shop had "borrowed" it from the previous owner. I've subsequently replaced it, but they're are to find and not cheap...
Mitch Leland
"03" 996 C2S-LS3 V8-480 HP
"84" 911 Turbo Look-Sold w/ found memories
Old 03-27-2011, 06:55 AM
gearhead
Then you are already through the hard part of what it would take to crack open the gearbox and have a look see. Just remove the drive flange and the side cover bolts and take a peek at your ring and pinion (drain your gear oil first. ). Then you'll know for sure whether it's open or LSD.
1974 914 Bumble Bee
2009 Outback XT
Old 03-27-2011, 07:26 AM
What does the ZF LSD look like.
I know they are VERY expensive... worth a lot of $$$$
Old 03-27-2011, 09:45 AM
