kinda freaking out, input please! engine/ oil issue
So the past couple of days my 83 has been up on ramps because i decided to try and find an oil leak, remove the ac and put my rs panels in. First thing i did was clean up as much of the underside of the engine (than i let the car sit for a day and nothing). Next day i decide since the oil leak isnt presenting itself ill install the door panels and take the upper/ easier parts of the ac out. That leads me to this evening when i go out to see if the engine has any fresh oil spots and it does. nothing major just a nice little trail ending at the oil sump plate. as im looking around im horrified to see this. Im pretty new to the porsche thing but, my gut is telling me WTF. can someone please, please please tell me what is wrong here. it looks as if im missing a half moon seal or something. this is at the rear most dead center of the block. if this is the case how does something like this happen and is there a fix?
Old 03-26-2011, 11:06 PM
DUK DUK is offline
DUK's Avatar
Help us out here. Point to where you're talking about. Do you have any more clear pics?
I'm suspecting the crank seal.
75 911 Indian Red- RUFWAN2B 2000 Boxster
2000 & 2007 Dobies
www.stahlwerks.com Cages and preparation for your Porsche
“People who never make mistakes must get tired of doing nothing”
Bill : The origin of the orgy of Porsche
Old 03-27-2011, 05:02 AM
Mo money = mo parts
Same. I can't see the location of the oil you're referencing.
Greg
86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten
65 Ducati Monza 250 & 66 Monza Junior (project)
"if you are lucky enough to own a Porsche, you are lucky enough"
Old 03-27-2011, 05:19 AM
I think he is talking about this
1986 3.2 Carrera
Old 03-27-2011, 05:22 AM
1986 3.2 Carrera
Old 03-27-2011, 05:27 AM
Targa Time's Avatar
That opening is supposed to be there. If you are getting oil from that area it is probably from the Nose Bearing Seal or the Intermediate Plate Gasket.
Old 03-27-2011, 05:39 AM
kodioneill's Avatar
Thumbs up
Half moon seal , is that a triumph engine?
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 03-27-2011, 06:22 AM
Thanks Ben the areas you circled are the area i was refering to.
Old 03-27-2011, 06:29 AM
Senior Advisor
James Brown's Avatar
OMG, WTF, I was looking for a quart or 2 of oil on the ground. You do spook easy Ramathron, trust the engineers.
08 Cayenne Turbo
Old 03-27-2011, 09:19 AM
Possibly spook easily. I'm coming from I've always worked subarus where leaks are easily found and fixed and every thing is suppose to be sealed. Lol
Anyhow what might the issue be and what is the fix involve?
Old 03-27-2011, 10:12 AM
steely's Avatar
A better pic would help. Do you have a macro button on the camera?
I second Targa Times' suggestion. If you can see oil on top, could even be a cam tower oil line.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 03-27-2011, 10:28 AM
You can dust the engine block with a very light coating of baby powder. The powder will stick to the wet (oil) areas and you can trace it back to it's origination point.
1982 SC
Old 03-27-2011, 11:06 AM
HarryD's Avatar
How much oil are you using? If it is less than 1quart/1000 miles, "Don't worry, be happy".
The factory says that normal consumption can be as high at 1 quart/700 miles.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 03-27-2011, 01:34 PM
