kinda freaking out, input please! engine/ oil issue
So the past couple of days my 83 has been up on ramps because i decided to try and find an oil leak, remove the ac and put my rs panels in. First thing i did was clean up as much of the underside of the engine (than i let the car sit for a day and nothing). Next day i decide since the oil leak isnt presenting itself ill install the door panels and take the upper/ easier parts of the ac out. That leads me to this evening when i go out to see if the engine has any fresh oil spots and it does. nothing major just a nice little trail ending at the oil sump plate. as im looking around im horrified to see this. Im pretty new to the porsche thing but, my gut is telling me WTF. can someone please, please please tell me what is wrong here. it looks as if im missing a half moon seal or something. this is at the rear most dead center of the block. if this is the case how does something like this happen and is there a fix?
Help us out here. Point to where you're talking about. Do you have any more clear pics?
I'm suspecting the crank seal.
75 911 Indian Red- RUFWAN2B 2000 Boxster 2000 & 2007 Dobies www.stahlwerks.com Cages and preparation for your Porsche “People who never make mistakes must get tired of doing nothing” Bill : The origin of the orgy of Porsche |
Mo money = mo parts
Same. I can't see the location of the oil you're referencing.
Greg 86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten 65 Ducati Monza 250 & 66 Monza Junior (project) "if you are lucky enough to own a Porsche, you are lucky enough" |
I think he is talking about this
1986 3.2 Carrera |
1986 3.2 Carrera |
That opening is supposed to be there. If you are getting oil from that area it is probably from the Nose Bearing Seal or the Intermediate Plate Gasket.
Half moon seal , is that a triumph engine?
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
Thanks Ben the areas you circled are the area i was refering to.
Senior Advisor
OMG, WTF, I was looking for a quart or 2 of oil on the ground. You do spook easy Ramathron, trust the engineers.
08 Cayenne Turbo |
Possibly spook easily. I'm coming from I've always worked subarus where leaks are easily found and fixed and every thing is suppose to be sealed. Lol
Anyhow what might the issue be and what is the fix involve? |
A better pic would help. Do you have a macro button on the camera?
I second Targa Times' suggestion. If you can see oil on top, could even be a cam tower oil line.
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
You can dust the engine block with a very light coating of baby powder. The powder will stick to the wet (oil) areas and you can trace it back to it's origination point.
1982 SC |
How much oil are you using? If it is less than 1quart/1000 miles, "Don't worry, be happy".
The factory says that normal consumption can be as high at 1 quart/700 miles.
