I'm closely following this thread since I'm considering installing an SW chip soon.
Good luck!
Ray 1986 Turbo-Look Cab White Gold/Burgundy |
RETIRED
Likely your prior attempts misaligned one or more of the the power pins or ground. Pull the connector and look to see if anything is obvious. Do you hear the DME relay clicking when you cycle the ignition? Dicking around with the box and such can also send the DME relay to an early grave. If it isn't clicking swap in another. If that isn't either.....you have a power in issue. Either 12v constant or 12v switched.
If you don't have a spare....get one, cheap part and cheap insurance. I did...wasn't the problem but now I have a spare so when it does go.....I have one. If it's one the Hungarian made ones, they are less hardy than the others. A test lamp or meter will tell you if you are getting power. There are a few threads on the subject and Ingo is a valuable resource. If you are getting requisite power to the loom, then you can test downstream to determine if the box is getting power and sending it down at the other end.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel Last edited by Joe Bob; 04-01-2011 at 11:22 AM.. |
Young enthusiast
The DME relay (looks kinda like a printer toner) was replaced about 3 months ago, so it shouldn't be the problem. I hope the white connector wasn't damaged in one of my previous attempts to hook it up to DME
BULLET 1989 Porsche Carrera 3.2 coupe |
RETIRED
It still needs to get power. Turn the key and listen or feel for the click.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Young enthusiast
The saga ends - engine starts now!
SW chip was installed the wrong way, so i had to take everything back apart and flip the chip around. Three remaining questions: 1) The engine now idles at 1100 rpms with the SW chip - is that normal? 2) Should I leave the white Pin 10 wires connected or disconnect them? 3) Was there significant damage done to the control unit when I tried starting the engine with the SW chip installed backwards?
BULLET 1989 Porsche Carrera 3.2 coupe Last edited by Porsche 911; 04-01-2011 at 01:03 PM.. |
RETIRED
Probably no damage. As to adjusting the idle, that question should be directed to SW. He does so much custom mapping that any speculation w/o specs would be stoopid. If it was an off the shelf chip....yeah the collective may have an opinion.
There IS an adjustment at the throttle body. Since it's mechanical it can always changed back....
Flat Six
911Chips.com - Motronic DME Update s-e-a-r-c-h
Dale 1985 Carrera 3.2 -- SOLD 2026 Jaguar F-Pace / 2025 Ford Bronco Sport |
Dont use the pictures/wording on the chip. sticker orientation can be misinterpreted. There is an indentation on one end of both the stock and SW chip, in the middle of the short side of the chip. If memory serves me well it should point AWAY from the Circuit board. Check.
EDIT - look on the 911chips website to see orientation. Don't trust me. hehehe |
Diss Member
It is possible to damage the DME by reversing the chip but you would know it by now because it wouldn't start. You are good to go.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
Young enthusiast
Thanks for all the help guys. Follow-up thread - with instructional pics - is posted.
83 911 Production Cab #10
Get in the habit to copy the "following post link" into your posting so if this post end up in someone search, he will have access to it right away. So here it is; To all prospective Steve Wong chip buyers Have fun JJ
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Not cool putting it in backwards...I wonder which pins erroneously rx' power? Always go by the notch..pin #1 to the left of the notch while viewing notch at 12 o-clock position (I would imagine)..
OUCH.... Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
Young enthusiast
What do you mean rx' power
Porsche 911,
This thread is a huge help to anyone like me who's considering doing this. Thanks for taking the time to shoot the pics and post! Have fun!
just me
really happy with my SW chip. on my second now due to putting SSI's on my 3.2
if you're not in cali and you don't need to pass emissions unplugging the brown wire helps the engine as well. it is easy to find right near the main cable for the DME
1975 911s, 3.2l and 915 transmission front oil cooler RUF replica bumper ducktail and SC rear flares SW chip ssi's m&k 2 in 1 out sc front calipers PF 97 pads fuchs 16 x 7 and 8 225/ 245 toyo ra-1s 22/29 torsion bars 25mm Charlie Bars Neatrix bushings lowered and corner balanced DAS bolt in roll bar kirkey seat 5 point harnesses. http://www.hairydoggrrrage.com/ |
muck-raker
I had trouble finding my brown wire, due to the PO taping them to the harness with black electrical tape....just a heads-up.
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
Young enthusiast
The instructions refer to the '84-'86 3.2s a lot, and mention the '87 for idling speed adjustment, but do not say anything about the 1989, even though I'm showing a 1200 idling rpm post-install.
The chip doesn't get damaged when it is installed backwards. So don't worry. The idle speed is adjusted at the throttle body and the mixture is adjusted at the AFM bypass screw.
Also make sure the idle microswitch engages when you let off the throttle. If not idle won't be stable. Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
Young enthusiast
I've tightened the idle adjustment screw behind the yellow cap clockwise until it can't be tightened anymore.. now i'm trying to bridge B and C in the rubber test socket. How does the throttle body come into play here (not in the instructions)?
the screw on the AFM is for the idle mixture. If you tighten the screw you won't allow air to bypass the flapper and as a result all air needs to pass through the flapper. This will make the idle mixture very rich. The basic setting is to have it three to four turn loosened.
The throttle body has the stop adjustment that sets the opening of the throttle plate at idle. That in combination with the ICV decides how much air is introduced into the engine and this defines the idle speed. ingo
