Help! I can't stop the acid!
A few weeks ago I found that my lead acid battery had leaked.
I quickly removed it. I then coated the damage in baking soda and washed with water the next day. The day after that, I found fresh "white stuff" appearing. Then, over a few evenings I did a very thorough soda and washing job. I would let soda sit for a day, then rinse it. Then, I would run through 1/2 gallon of water mixed soda, then run through about 5 gallons of water. I even scrubbed with scotch bright. I also pulled the three plugs from the bar down below to assist with the draining. I thought I had it knocked out. Now, about a week later, this is what I find: ![]() ![]() ![]() ![]() ![]() I'm out of ideas. What should I do? Interesting how much "white stuff" is around the three holes, but none around the drain slit which had just as much of the rinse water coming through. As a post this, I can feel little spots of burning on my hands... Just from looking at it and taking photos... How can it be, how can there still be acid there?
1985 BMW 325e - 2 Door 1982 Porsche 911 SC Euro Spec 1965 Land Rover Series IIa Restoration Project 1999 Land Rover Discovery II 2002 Suzuki SV650 Naked Bike Last edited by maxman; 03-31-2011 at 08:13 PM.. |
Banned but not out, yet..
Ripped from the innertube...
What you should do then is take out any removable material out the trunk and flush with a lot of water. You should use an neutralizing agent to clean the rest of the trunk then. This will turn the acid into a (rather) harmless salt that can then be removed without the danger of being hurt. Description of a neutralizer: Wildpower Battery (http://www.wilpowerbattery.com/ACCESSORIES/n3.htm ) Or you can use simple baking soda Google Answers: spilled battery acid
An air cooled refrigerator. ‘Mein Teil’ |
I think I'd take everything out of the trunk, wrap the electrics and pressure wash with a neutralizer solution.
This thread should be a lesson to those who still want a lead acid battery.
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
You've got the right approach, unfortunately you can't see underneath the battery tray and inside the hollow(!) fuel tank support that runs across to the other side.
What I found when I cut mine open (after I took a wire brush to it): Optimas for me from now on
Kurt |
Put down 3 boxes of dry baking soda for tonight. As I was removing the battery, way back when, it knocked the headlight washer and it leaked a bunch of fluid onto the acid. There was quite a bit of bubbling. Could that be part of this? Did I make some sort of super acid?
Plan for the moment is to track down some commercial acid neutralizer in liquid form and wash like crazy this weekend.
1985 BMW 325e - 2 Door 1982 Porsche 911 SC Euro Spec 1965 Land Rover Series IIa Restoration Project 1999 Land Rover Discovery II 2002 Suzuki SV650 Naked Bike |
AutoBahned
don't use dry baking soda -- make a slurry with water and try to get it into all crevices
use a syinge or tube with a pump or fill your mouth with the conc. baking soda soln. and blow it in |
I'll do some more of that over the weekend. Hoping for damage control right now.
Thanks for the tips. I'll keep you posted. Going to give a call to a local restoration shop that I know tomorrow. I'll see if they have any good tips.
Senior Advisor
gobs and gobs of water.
08 Cayenne Turbo |
Coke works pretty good too.
You know that stuff's illegal!!!!!!!!
Max Sluiter
I think it's a play on "white stuff" and "acid"
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
abides.
I've seen it used to clean the corrosion off of battery terminals. I don't know about using it to clean up battery acid.
Graham 1984 Carrera Targa |
After you clean it up you have to vent the battery to atmosphere with the small plastic hose.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
AutoBahned
That looks sneakingly like bicarb once the water has evaporated. Scrape up some of that white stuff and place a drop of vinegar on it. My guess is that it will foam.
If it does, you just need to rinse, repeat and repeat again with plain old water.
72 911T 2.4 MFI 2017 Escape SE 2.0 turbo 2020 Honda Civic Touring Sport 1.6 turbo 10' Madone 5.2/17' Lynskey ProCross |
Maxman,
Personally, after cleaning the battery terminals, connectors, and tray, if you find additional 'corrosion" I would get rid of the battery. JMHO, find the Interstate "distributor", not a dealer, and ask for a 'blem' that is correct for your car. We just picked one up for Dad's 79 for $50. Clean all components with a mixture of baking soda, water and an old toothbrush. Rinse with regular water. Clean and 'touch-up' as necessary. The 'red' batteries are very good, but I'm not sure they're that much better than a regularly maintained battery. Prior to installation of a new battery, and following the proper cleaning of the post's and battery wires, spray a small amount of WD-40 on the posts and connectors, wipe all excess off. The WD will help assure a good connection and help with the out gassing of the battery. Just my .02 Karl 88 Targa |
