Thanks Tony.
Maybe you can help me out.
I disconnected the battery. I put the continuity on terminal 50 and a good ground on the ignition switch and got no sound , so that s good with no short to ground.
I disconnected the yellow wire at the starter.
I checked terminal 30 (both) on the ignition switch and got a sound, which I assume means the is a ground short somewhere.
I unplugged the harness at the 14 pin connector.
I retested terminal 30(both) at the ignition switch and still got a tone.
Does that mean I have a short to ground somewhere between the ignition switch and the 14 pin
connector?
To recap. I have unplugged the ignition switch and unplugged the 14 pin connector. I am getting a continuity sound at the 30 terminals on the ignition switch
1982 SC
Old 04-22-2011, 12:16 PM
Sorry
I got my terminals confused. If I am getting continuity at terminals 30 at the ignition switch with the battery disconnected then I must have a ground fault or short to ground between the two red wires and the switch, right!?
1982 SC
Old 04-22-2011, 01:51 PM
