-82 SC 993 convert fuel gauge problem.
Gentlemen.
My -82 SC 993 convert, with 993 gauges, shows full tank constantly. When it gets down to the reserve fuel level, the light comes on but the needle is still showing full tank. I swapped the fuel tank sender unit and the result was the same. As long as I have had the car, it's been like this.
Does anyone have a clue what the problem might be? Does the 993 fuel gauge work the "same" way as the older ones?
G
Old 04-07-2011, 01:15 PM
CabMike's Avatar
Hoyo,
I put 964 gauges in my 1983 SC a few months ago. The values are different from the SC sending unit and the 964/993 sending unit. There is a small black box that goes between the gauge and the sender on the later cars but to use it you need to modify the sending unit. I ended up just sending the gauge to North Hollywood Speedometer and they re-calibrated the 964 gauge to work with the SC sending unit for about $150.
Works great now!
Mike
Mike
1983 911 Cabriolet (3.6L conversion)
Guards Red
2007 BMW X5
Old 04-07-2011, 01:48 PM
Alright, thanks for swift reply.
Do You know if the gauge will work if I just get hold of the black box?
If not, I just have to get the gauge recalibrated.
Once again, thanks.
H
Old 04-07-2011, 10:07 PM
CabMike's Avatar
I tried the black box and even modified a sending unit as described in another thread here on pelican but it did not work. If you do a search on 964 gauge install you can read where someone stated that they got it to work.
Mike
Guards Red
2007 BMW X5
Old 04-08-2011, 06:12 AM
