| Registered |
				What to do?  SW Chip or Pre-Muffler?
			Would you get a SW chip first or a pre-muffler?  I have stock 1985 Carrera.  Eventually, I'll get both, but I can afford only one project right now. Thanks. | ||
|  04-08-2011, 07:53 PM |
| Registered Join Date: Aug 2008 Location: Los Angeles, CA
			chip first wait and find a used premuffler whenever, $99 cheapo on e bay right now
				__________________ 1988 Carrera Coupe Last edited by m110; 04-08-2011 at 09:05 PM.. | ||
|  04-08-2011, 09:02 PM |
| SLR |
			Muffler first Cos SW will programe the chip for what you have done to your car. SLR. | ||
|  04-08-2011, 10:58 PM |
| Registered Join Date: Dec 2008 Location: Wilmette, IL
			You need to do a pre muffler along with an M&K muffler! I just did both along with the chip and it is well worth it! You shed about 25 pounds, breathes better, and sounds perfect. A nice mellow, deeper, rumble.
				__________________ 1987 Targa just about to hit 29k 2004 mazdaspeed miata wifes 1995 spec miata SOLD stupid fun! | ||
|  04-09-2011, 05:45 AM |
			I actually drove to  M&K to pick things up and met Ben, he is a super nice guy and builds a great product! I cannot endorse it enough!
|  04-09-2011, 05:49 AM |
| Registered Join Date: Jan 2001 Location: Iowa
			When I bought my SW chip there was a different one for cars with pre-muffler so you should do the latter first. I did them both at once and I recall the change was quite striking. But getting the old cat off took me two days and much cursing (+ heat + dremel), since hardly any of the bolts came out willingly.
				__________________ John C 1988 911 Carrera coupe 2002 BMW 530 | ||
|  04-09-2011, 06:02 AM |
| Registered |
			Get both.  SW chip is optimized for your exhaust set-up.
				__________________ '88 Carrera Coupe G.P. White | ||
|  04-09-2011, 06:04 AM |
			Not too bad. PB Blaster let it sit, re-apply and let it sit! I dremeled off two and those only took about 10 mins I just went part way through them and took a flat pneumatic chisel and knocked them off!
|  04-09-2011, 06:06 AM |
			IMHO, the chip makes the biggest difference by far in terms of driveability. Although there is a difference between the chips in terms of tuning with and without the added backpressure, I think this is small. Meaning I would rather have the chip first, might not be ideal but will work fine and better than he has now on a 20 y old car and better than just the bypass alone. You can always give Steve Wong a call, he answers the phone himself and posts on this board.
				__________________ 1988 Carrera Coupe | ||
|  04-09-2011, 06:19 AM |
